sudden timing issues?
Replied by Ht1kid on topic sudden timing issues?
The following user(s) Liked this Post: Digger65
20 Aug 2023 13:01
#111
- Digger65
Replied by Digger65 on topic sudden timing issues?
thanks cant seem to access it from UK maybe its not marked as UK dispatch
wil keep trying
D
wil keep trying
D
20 Aug 2023 13:09
#112
Put the username in maybe that will help
20 Aug 2023 13:33
#113
- Digger65
as an aside i thought the cases would have traces of Yamabond on the join but were completely clean
20 Aug 2023 13:37
#114
- Digger65
yeah found the seller, searched their 161 listings and that item not showing for some reason
no idea
D
no idea
D
20 Aug 2023 13:50
#115
Replied by MarkT on topic sudden timing issues?
Here's a direct link to the shaft HT1 kid posted, maybe this will help. You could also contact seller and ask. I've done this on UK auctions and sometimes they send to the USA even though the auction says they don't.
Ebay link to transmission shaft
20 Aug 2023 14:51
#116
- Digger65
thats great!
thankyou
D
thankyou
D
20 Aug 2023 15:13
#117
Replied by RT325 on topic sudden timing issues?
Do you have it totaly dismantled.
If not i think i'd be doing that first & closely inspecting all gears for damage & the case where the bearing sits.
I'm a bit behind on the story but you don't want to get to spending more money on parts than reasonable taking into account the rest of the bikes condition.
Sometimes its better to buy another motor if you can find a known good one.--just saying.
20 Aug 2023 18:31
#118
- Digger65
Yes it's all apart now
It all looks Rosy apart from the deforming of the needle bearing housing, (luckily no shards present other side of the casing)
i picked up the idle and kick gear reasonably priced NOS with the needle bearing the only item above £20 so far (apart from a few tools but don't mind that)
I have found someone who has repaired bearing housings just waiting in a price now
maybe I can find a crank case in meantime
will look again at the axle shaft as I can't properly discern if it's bent or just bearing moving in the seat a bit when I turn it
Happy to wait out the winter and taking my time to find the parts at a good price and then to slowly rebuild rather than rush it back together, only issue with that is retaining on my head where all the bits go, have photos parts schematics online, manuals and YouTube to help thankfully
The following user(s) Liked this Post: MarkT, RT325, Sneezles61
- Visitor
Replied by on topic sudden timing issues?
You might find cases in the US, but I would think very lucky to find any in UK? First thing I would do is to see if a bearing with larger OD is available. Then its simply a matter of machining the damaged housing to accept a larger bearing.
Gear shaft needs to be held in a lathe or put into a pair of vee blocks to check if its straight or not.
