76 DT400 second start first ride
Replied by Clegg on topic 76 DT400 second start first ride
Ok on the latch.. I tested this 50 pilot and the bike runs a lot better at the low throttle position. I also have the idle set at 1100 rpm (the electronic ignition helps there), seems to help with the 4 stroking when letting off the throttle.
I can actually apply 1/4 throttle and get to 35mph and hold it there. No hiccuping.
Ed
The following user(s) Liked this Post: AirborneSilva, Jammyyammy
Last edit: 22 Jul 2023 10:44 by Clegg.
22 Jul 2023 10:43 #11
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Replied by AirborneSilva on topic 76 DT400 second start first ride
I'll have to give the 50 pilot a try, also lower the idle speed to 1100.
22 Jul 2023 11:00 #12
Replied by msavitt on topic 76 DT400 second start first ride
I tried a lot of things with carb to reduce the chug chug. In the end I put a #55 pilot jet (#50 is stock) with a #190 main jet and maybe I lifted needle up a slot.  Runs amazing, meaning powerful and the chugging is very tolerable, even on a long curve
22 Jul 2023 13:26 #13
  • AirborneSilva
  • Platinum Member
  • Platinum Member
I've saved a few things I've read here from you guys in a word document so when the time comes for me to really deal with the surge I will have a few things to try. I'm always interested in hearing more so if anyone has other ideas please speak up, that surge is so annoying!
22 Jul 2023 14:28 #14
Hmmm, My DT400 had a 40 pilot and the Yamaha manual states a 40 pilot as stock. I know there are discrepancies in some of the literature.
Mine would break up like crazy on any main jet above 150.
Last edit: 22 Jul 2023 15:08 by Clegg.
22 Jul 2023 15:04 #15
I forgot to say the bike I am referencing is my ‘74 dt360a, which was had the  worse chugging symptoms. ‘78 400 was way smoother. I should have wrote it down but I think the stock pilot jet was #80 maybe because much larger carb?
22 Jul 2023 17:20 #16
Replied by Blackhat250 on topic 76 DT400 second start first ride
Try closing the Air screw to say just a half turn out, ride it and see ,,then post back result
If you aint mixin gas " you aint haulin Ass
23 Jul 2023 15:56 #17
  • AirborneSilva
  • Platinum Member
  • Platinum Member
That was one of the first things I tried, didn't help but thank you for the suggestion!
23 Jul 2023 16:42 #18
  • AirborneSilva
  • Platinum Member
  • Platinum Member
Hey guys, decided after the gym this morning I needed to take the 400 out again to see if I wasn't just being paranoid, below is a video I took after doing some laps around the hood.  I think this is excessive rattling but then maybe I'm just being paranoid, my DT2 is whisper quiet compared to the DT400...  The second video sounds even louder even though I took them seconds apart, sorry about the sideways video...
DT400 engine rattle
Rattle #2
www.youtube.com/shorts/XMWUmNnW4Ck
Last edit: 25 Jul 2023 11:11 by MarkT.
25 Jul 2023 09:49 #19
Ok"   sounds a bit rattly ,  i like the way your revs drop,[ no hanging]  it will run a long time like this, ,,just ride it ,
25 Jul 2023 13:54 #20
