Where to buy aftermarket blinker relay for 74 DT360?
- bluntz465
Replied by bluntz465 on topic Where to buy aftermarket blinker relay for 74 DT360?
It is evidently not the wiring diagram I was looking at either as it shows the pilot running off the signal circuit already.
1982 Yamaha IT465J
1982 Yamaha IT465J
- edelweiss
Replied by edelweiss on topic Where to buy aftermarket blinker relay for 74 DT360?
OR, you can get one of these from Amazon for $6.50. Weww heww!
www.amazon.com/gp/product/B000CSYL3C/ref...ages00?ie=UTF8&psc=1
28 Apr 2015 08:02
#22
- AT6 DRIVER
Replied by AT6 DRIVER on topic Where to buy aftermarket blinker relay for 74 DT360?
TOPIC: ARE YOUR TURN SIGNALS NOT BLINKING? MAYBE YOU NEED A WINKER??
This is a post I submitted a while back- look under 1975 DT400 for the solution if it is the same original 3 wire blinker on your bike.
1975 DT 400B
If it moves and shouldn't , use duct tape. If it doesn't move and should, use liquid wrench.
31 May 2015 00:51
#23
- GALAXY991
Replied by GALAXY991 on topic Where to buy aftermarket blinker relay for 74 DT360?
was wondering if anyone has ever came across this issue:
got a 1974 DT175 previous owner removed the turn signals and flasher used it more of a dirt bike I replaced the signals and picked up a OEM flasher used pn#FN637L when I installed the flasher and turn on a blinker the flasher buzzes like a horn but does not blink the turn signals indicator light seems dim compaired to nutral and bright headlight indicators in the tach the turn lights themselves are very bright but just stay on with the flasher relay buzzing.
this is a 6volt sys I replaced all the bulbs with new ones verifying they were 6 volt the battery is new also checked the charging sys it is working perfectly
05 Apr 2022 09:41
#24
- Sneezles61
Replied by Sneezles61 on topic Where to buy aftermarket blinker relay for 74 DT360?
Perhaps a left handed question... Can you swap the wires around on the "winker can" to be sure it isn't a one way only hook up?
Sneezles61
Sneezles61
05 Apr 2022 12:42
#25
