fork strip travails
Replied by MarkT on topic fork strip travails
Yamaha did specify loctite on those bolts starting around 1977-78...  I've come across a few that have been loctited in.
23 Sep 2021 16:54 #21
Replied by RT325 on topic fork strip travails
They weren't selling enough fork damper holding tools back then lol, so add loctite that'll do it.
23 Sep 2021 20:08 #22
Replied by shyted on topic fork strip travails
judging by the condition here's my two bobsworth. In a vice fully assembled ,plenty of light .
Clean the whole thing up so you have full access un hindered by rust and debris. Get a heat gun and warm the bottom of the tube .If you have no heat gun ,get the kettle on and soak in red hot water for a while several times. I have never yet failed on any fork leg and i've undone hundreds. Never ever used power tools ,nothing against that method , but i keep pressure on with a good quality good condition Allan socket half inch drive with a meter long breaker bar . They always go . If it gets serious and the Gorillas have been there before you then you need a flame and appropriate
tool to bash in the end and then it will come out . Make sure you take them crocs off your feet first though .
24 Sep 2021 05:36 #23
  • TStanb
  • TStanb's Avatar Topic Author
Replied by TStanb on topic fork strip travails
Gentlemen
….after many weeks I have overcome my problem. The tapered broom handle trick didn’t work because it would not grip the head of the damper rod.
if you look at the photos you can see that a butchered 8mm socket did the trick.
next quest…how do I remove the old fork seals? They look almost a permanent fixture…I’m very concerned with damaging the soft aluminium at the top of the lower legs
12 Oct 2021 14:18 #24
Replied by Schu on topic fork strip travails
I haven't tried this method yet, but I saved it for future reference because I thought it was pretty slick.
yamaha-enduros.com/index.php/forums/spec...rk-seal-puller#85522
The following user(s) Liked this Post: Sneezles61, TStanb
12 Oct 2021 14:57 #25
