fork strip travails
- TStanb
fork strip travails was created by TStanb
Hi
I'm having a real problem stripping down the forks on my 1G1 model.
The Allen bolt at the bottom just spins, even with an airgun and the forks compressed. On my XT600, you simply fabricate a locking tool on the end of a metal rod and lock up the damper gubbins.
Any suggestions?
Any suggestions?
22 Sep 2021 01:27
- Swoop56
Replied by Swoop56 on topic fork strip travails
I have always used an impact driver with an Allen Key Socket , and with the forks compressed .
Never failed yet .
Never failed yet .
The following user(s) Liked this Post: TStanb
22 Sep 2021 02:26
Replied by MarkT on topic fork strip travails
Grind a tapered end onto an old hardwood broomstick and tap it into the top of the damper rod. The zip the bolt out while holding the stick.
The following user(s) Liked this Post: apex, TStanb
22 Sep 2021 03:38
Picture might help... grind or whittle a gentle taper on end of stick that's small enough and tap into end of damping rod.
Or if you have deep pockets, Racetech sells a tapered aluminum tool that works the same way
The following user(s) Liked this Post: Gr8uncleal, TStanb
22 Sep 2021 04:12
- darinm
Replied by darinm on topic fork strip travails
Heat can really be your friend on these too, I've had good luck leaving a heat gun on high about 1" away for 20-30 minutes. May discolor the finish though, but it does help a lot.
1972 Yamaha CT2 175
1972 Suzuki TS185 Sierra
1997 BMW R1100R
2013 Yamaha XT250
1997 BMW R1100R
2013 Yamaha XT250
22 Sep 2021 09:49
- apex
- Content Contributor
Replied by apex on topic fork strip travails
Mark T's trick always works for me. I also find holding the fork tube extended with held pressure pops the bolt loose using an impact.
Allrighty Then
22 Sep 2021 10:09
- TStanb
Replied by TStanb on topic fork strip travails
Unfortunately I have tried the wittled stick method and it doesn't grip onto anything at all. In fact, when I try to look down the stanchion, there doesn't appear to be a cup or a hole at all...more like a raised platform. I'm getting anxious
Also ... after I've removed the fork seal circlip and retaining washer, should the stanchion slide out of the lower tube with a good tug, bringing the seal with it?
22 Sep 2021 10:39
We didn't have that model in the US but normally seal does not come out with the tube. Also, someone may have swapped forks with a much newer model or something... I don't recall seeing the older style Yamaha damping rods without a hole. Even the newer bikes with conventional forks have a hole in top of damping rod. Maybe you just haven't whittled stick small enough.
Can you post pics?
Can you post pics?
22 Sep 2021 11:12
- TStanb
I’ll post some pics tomorrow
22 Sep 2021 14:46
- Lizeec
Replied by Lizeec on topic fork strip travails
In your first post you mention the forks are compressed, I always leave the spring in and the the top bolt in and out the forks extended, the spring pressure helps hold the dampening rod, then I use an electric or air impact gun on the Allen bolt and it zips loose every time I have tried, probably have rebuilt 25-30 sets of forks.
The following user(s) Liked this Post: MarkT, Ht1kid, TStanb
22 Sep 2021 16:41
