Need some help with Electrical Wiring for DT125FC & DT125D
- Yanduro
Replied by Yanduro on topic Need some help with Electrical Wiring for DT125FC & DT125D
Thanks again for the information.
08 May 2021 01:16
#11
- Yanduro
Today I finally received the additional images I required that showed the colours.
As you can see from the images that I’ve uploaded, the colours for the stator seem to be a match for the most part, beside them containing white stripes. The socket on the harness has two black wires going into 1 pin while the stator cable only has one. – I think this is perfectly fine and should work.
Due to the Wiring Harness being originally for a “Yamaha DT100C” they didn’t have a Tachometer so it used the Speedometer as a place to put the “Neutral”, “High Beam”& “Flasher Pilot Light” together this required 4 bulbs. I still wish to use my Tachometer but I assume I could use those in its place, but I still require an additional one for my Speedometer. Would this Wiring Harness be capable of doing it without modification? Also due to the Tachometer being functionality mechanical and utilizes a Tachometer cable Ass'y, I don't think I am missing anything else to get this working. - Or am I?
Thanks for making me aware that the DT100C is shorter than the DT125. I am not sure how I would definitively know if the size would be an issue, but I suppose I should start from the front when starting the wiring process.
I could be wrong so please let me know, as I am a newbie.
- Yanduro
More Images.
21 May 2021 10:26
#13
- Yanduro
More Images
22 May 2021 00:23
#14
