Removing oil tank and air cleaner form a '74 360DT - any Tricks in Removal?
  • warmblood58
  • warmblood58's Avatar Topic Author
Started to pull air cleaner box and oil injection tank but . . . . no go, all 10mm's removed as is air intake snorkle off airbox. Any tricks? Anything else I need to pull to make this work? Help! Thanks! Pardon typo in Subject, typing too fast
Last edit: 17 Feb 2021 16:34 by warmblood58. Reason: typo
17 Feb 2021 16:30 #1
hmm...I remember it being a tight fit and worrying about scratching nice green paint but didn't have an issue removing.  I do think that I had the tool tray, silencer and exhaust pipe off...maybe because I couldn't get it out?
17 Feb 2021 17:03 #2
  • warmblood58
17 Feb 2021 17:28 #3
  • warmblood58
Some wiring harness shifted might work - would love to not remove exhaust at this time
17 Feb 2021 17:30 #4
Did you take the cap off the oil tank?
17 Feb 2021 19:20 #5
17 Feb 2021 19:33 #6
  • warmblood58
17 Feb 2021 20:02 #7
Ichiban Moto has the solution.  Skip to about 1:45
17 Feb 2021 20:56 #8
same frame setup as a DT400. You will need to remove the exhaust if I recall. It's sort of a puzzle how it goes together, and there is a definite order of things.
The following user(s) Liked this Post: nhsteve, warmblood58
17 Feb 2021 21:05 #9
  • warmblood58
18 Feb 2021 07:03 #10
