1975 DT250B Clutch cable woes..!!
  • Andy L
  • Andy L's Avatar Topic Author
1975 DT250B Clutch cable woes..!! was created by Andy L
First of all HNY to all members and moderators.
I am looking for a new clutch cable for my '75 DT250B. Simple swap you would think, but after buying (and then returning) no fewer than 3 already I'm stuck..!! They always come up too short. At worst 120mm or at best only 40mm short, either way they have all been too short. Outer cable adjustment isn't the answer because it only gives a variation of roughly 25mm max. Nether is the routing of the cables I've tried as I have a detailed service manual showing exact cable route. My old clutch cable is totally knackered such that I can't even use the various 'components' on it to make my own cable from scratch. Yamaha changed the position of the clutch rod actuator arm from the top of the engine to the bottom for the 1975 B models. The critical measurement seems to be the inner wire length which is 1260mm nipple to nipple on my old cable. Even accepting this has stretched over the years I still need an inner wire length of minimum 1235mm. Can anyone point me in the right direction for a supplier please? I know one option would be to buy a whole short cable and use it's components to 'build up' a new cable using a kit, but surely before going down this path there must be a supplier somewhere? I'm located in the U.K. but if necessary I'd consider taking a hit on the cost of P&P + import tax from the U.S.A. Any help would be greatly appreciated, thanks AndyL.
09 Jan 2021 01:30 #1
Replied by Gr8uncleal on topic 1975 DT250B Clutch cable woes..!!
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=393082469923&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by 1971DT250 on topic 1975 DT250B Clutch cable woes..!!
Just to add my 3 cents worth of experience on measuring old cables. The sheath will compress more that than the cable stretches making it confusing to measure. I've read that there have been some aftermarket cables made by measuring used cables for dimensions resulting in incorrect lengths.
I have only '71-'73 Enduros. I've measured some really used ones and found that the cable was almost the same length as NOS but the sheath was much shorter.
09 Jan 2021 05:25 #3
Yes, I had issues with the new clutch cable that came with my RT2 as well. In this instance, the outer cover was so short in relation to the inner cable that it wouldn't even reach the crankcase cover! :EEEK I ended up buying a nos period repro and that fitted fine.
09 Jan 2021 06:16 #4
Replied by MarkT on topic 1975 DT250B Clutch cable woes..!!
Early models have the worm gear actuator in the side cover.
1974-1976 250/360/400 have the actuator underneath the engine.
1977 on (monoshock aka "MX" in some countries other than the US) had the lever on top.
Rather than scrounging for a used or poorly made reproduction you might try buying the cable new from Yamaha?
www.partzilla.com/product/yamaha/363-26335-03-00
CMNSL - www.cmsnl.com/yamaha-dt250-1975-usa_mode...reclutch_3632633503/
Good luck and hope you are up and running soon!
The following user(s) Liked this Post: Pedalcrazy, Jack
09 Jan 2021 07:50 #5
Replied by Wessi on topic 1975 DT250B Clutch cable woes..!!
Hello,
i bought mine for the same Model on Yambits.
yambits.co.uk/
Perfect fit, no problems.
Best Regards, Guido
09 Jan 2021 10:33 #6
  • Andy L
Replied by Andy L on topic 1975 DT250B Clutch cable woes..!!
Thank-you to all who have replied so far. Your replies have opened up a few more avenues for me to explore. Very best regards AndyL.
10 Jan 2021 00:29 #7
Replied by JimA on topic 1975 DT250B Clutch cable woes..!!
Did you try Speed and Sport they have alot of NOS parts.
Jim
10 Jan 2021 21:13 #8
