‘75 Dt400 rear fender
- cydways
‘75 Dt400 rear fender was created by cydways
I am starting to put together a game plan for my latest Project purchase. The bike is a little rough around the edges but all and all I think it was good fit for me. My first question is regarding the rear fender. This bike has a plastic rear fender which I believe is supposed to be metal but it fits/mounts surprising well. I’m not sure if the ‘77 ‘78’s had plastic rear fenders or it could just be off of something random. If anyone can tell please chime in.
As for the metal rear fenders, does the DT series share rear fenders throughout or are they proprietary per model? With my brief searching on eBay it seems easier to find a DT250 fender over the DT400.
Any info would be appreciated
07 Dec 2020 20:39
Replied by MarkT on topic ‘75 Dt400 rear fender
Great project!
Looks like maybe a Preston Petty rear fender.
Those could be early Works Performance rear shocks too.
You can look up part numbers online and see that the stock fenders are the same... note that the 75 250/400 models are shown under 1976 on sites like Partzilla.
07 Dec 2020 21:08
- run103
Replied by run103 on topic ‘75 Dt400 rear fender
1974 DT's to 1976 DT's all had the same rear fenders and they are getting hard to find in good shape. Remove the mag cover and clean it up before you spin the flywheel and damage the pulser. That's even worse than the fender to find. I see you have an aluminum back rim also Are ya building a rider or a show bike
Doug
Doug
08 Dec 2020 07:20
- cydways
Replied by cydways on topic ‘75 Dt400 rear fender
Thanks for Petty lead, Mark. It looks like some good stuff for future projects but it seems at least current inventory they are all smooth fenders this rear fender has two molded flat spots for the rear mounting lugs. I am unsure on the rear shocks, I didn’t realize they were not the originals until after hauling the bike home.
Run103 Thank you for the fender confirmation, I am going to snag a 250 rear that I’ve tracked down. The previous owner said the bike would fire but it wouldn’t stay running and it looks like he dug into the wiring which I will have to go through but after pulling the carb and boiling it giving it a good cleaning the bike fired right up and seemed decent, So it looks like I got lucky with the Pulser. The lower jug gasket was leaking a bit and the clutch didn’t seem to engage but that was all the info I needed. The bike will be torn down completely and gone through.
It will most definitely be a runner. I ride/drive all my vintage stuff because that’s what it’s all about. This will not be a 100% original bike. It will get slight modern touches that I usually keep very subtle. On my list is a mx400 jug and piston as more hp is always welcome on anything I build.
08 Dec 2020 12:06
- run103
Cydways That bike will be great.. Try Octane lighting for LED Headlight bulbs that fit the original bucket. I clean that mag area and then paint the inside of the cover wit heat paint and then seal it up so water cant get in So far all of my restores are running great all using stock ignition parts. I just did a 250 mile cross country ride on my DT400 with 4 other guys on new bikes and the thing did amazing. One thing that saved me was new seat foam because that's virtually the suspension on that bike. Im running stock thermal flow shocks with 15 weight oil and the same in the forks. I would love to add about 2 inches to the suspension and find a supple rear shock that doesn't just blow thru the compression damping. Hey the suspension keeps me from trying stupid things at my age
Doug
Doug
08 Dec 2020 12:39
