Oil pump advice required 1974 DT250
  • MrBernzo
  • MrBernzo's Avatar Topic Author
Replied by MrBernzo on topic Oil pump advice required 1974 DT250
I wasn't able to make any progress with the pump. Kept leaking form the Shaft. I managed to track down another pump and it's on it way to me now.
I pulled this one down to see if I can rebuild it. There was a bit of crap inside but overall clean. Looks like the tiny seal in the pump spindle is the leaky one.
Going to order a rebuild kit and see if I can get this one running again.
15 Oct 2020 23:41 #21
Replied by MarkT on topic Oil pump advice required 1974 DT250
You can buy the seals from Yamaha.
16 Oct 2020 04:07 #22
  • MrBernzo
Replied by MrBernzo on topic Re:Oil pump advice required 1974 DT250
I have struggled to find part numbers for the seals through Yamaha, particularly the small seal.
Sent from my moto g(7) using Tapatalk
16 Oct 2020 04:34 #23
Here is the parts list I have:
Small internal driveshaft seal: 93104-06108-00-00
Primer end seal: 93101-10090-00-00
Pump seal : 93104-14059-00-00
The following user(s) Liked this Post: MrBernzo, Jewelkutter
16 Oct 2020 04:45 #24
Replied by Wessi on topic Oil pump advice required 1974 DT250
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=133051403365&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
Replied by Gr8uncleal on topic Oil pump advice required 1974 DT250
If anyone is interested, Simply Bearings is one of the "go to" companies in the UK for seals, bearings etc.
18 Oct 2020 05:40 #26
  • MrBernzo
Sensational! I have been looking for these part numbers. I searched the numbers on my local dealers website and it shows all parts as available in Australia. All up $42 for the seals and gasket.
Thanks Mark.
19 Oct 2020 04:43 #27
  • MrBernzo
