DT400 cylinder
  • mnsuys
  • mnsuys's Avatar Topic Author
DT400 cylinder was created by mnsuys
Just a quick question.....are the cylinders across the DT400 range (twin shock to monoshock) identical and are there any markings or identification on the cylinders to distinguish them? I think DT400 only produced for 4 years, 2 years twinshock and 2 years monoshock.
05 Sep 2020 02:33 #1
  • mnsuys
Replied by mnsuys on topic DT400 cylinder
Kinda found my answer by using SEARCH....its a wonderful tool..
Seems DT400 twinshock and monoshock model cylinders are not interchangeable....
Still need to know how to distinguish between the 2?
05 Sep 2020 02:40 #2
Replied by RT325 on topic DT400 cylinder
That's good to know. I would have thought they'd all be the same so far as swapping over goes.
05 Sep 2020 04:41 #3
Replied by Gr8uncleal on topic DT400 cylinder
There may well be code(s) stamped on them, probably towards the bottom. You might have to rub away some grime first!
05 Sep 2020 05:30 #4
Replied by JayB on topic DT400 cylinder
Here are a couple of pictures of twinshock 75/76 DT400 USA model cylinders.
05 Sep 2020 07:06 #5
Replied by MarkT on topic DT400 cylinder
They will swap. Someone here has done it. Reed valve flange is different size on the monoshock so that would need to be swapped...
And then you might have trouble finding an intake manifold that lines up if using stock carb/airbox or could work just fine with the earlier/later manifold that matches cylinder flange?
05 Sep 2020 07:23 #6
500 being the model code for the 1975 DT400, not the size of the engine!! :ROFLOL
05 Sep 2020 09:20 #7
  • Thebassguitarist
  • Thebassguitarist's Avatar
Replied by Thebassguitarist on topic DT400 cylinder
The main difference is in the reed cage mount. Its slightly taller on the dual shock models. The intake port on the older models is different as well.
Using an earlier model cylinder on a monoshock bike is possible, but not ideal. You have to use the older reed cage and intake manifold. By doing that your carburetor goes off in a different direction. That causes the top of the carburetor plunger to interfere with the exhaust crossover. Angleing the carb works to remedy this but you still are not able to use the stock intake box. I just use an uni pod filter and bigger main jet.
05 Sep 2020 21:20 #8
Thanks for posting confirmation that it "basically" fits and describing the intake/carb/air box differences and alignment issues. :likey
06 Sep 2020 08:37 #9
