How do you get a broken brake electrical cable out of a ‘74 DT360A?
- mrstangblb
How do you get a broken brake electrical cable out of a ‘74 DT360A? was created by mrstangblb
I don’t want to mess anything up by digging this thing out, but how do you get a broken brake electrical cable out of the front brake housing on a ‘74 DT360A? I’m attaching a picture of what I’m talking about.
Barry
KK4RXN
Jeremiah 29:11-13 / John 3:16
12 May 2020 16:45
- Pedalcrazy
Replied by Pedalcrazy on topic How do you get a broken brake electrical cable out of a ‘74 DT360A?
Sometimes if I don't know what I'm dealing with I'll buy the new one and then I'll see how it goes in and what's left there to remove. Just how I might go about it. Good luck.
The following user(s) Liked this Post: mrstangblb
Replied by RT325 on topic How do you get a broken brake electrical cable out of a ‘74 DT360A?
Look underneath & 'might' be a little slot to push a srewdriver in to release a tag that click in there [or is the my old suzuki], gotta be something similar to that.
The following user(s) Liked this Post: 2fishkev, mrstangblb, JimA
12 May 2020 19:05
- LongStride
Replied by LongStride on topic How do you get a broken brake electrical cable out of a ‘74 DT360A?
There is a locking tab that holds it in, should be a hole in the bottom where you can press it back with a small pick and free the switch
2ET703 Central Texas
The following user(s) Liked this Post: MarkT, mrstangblb
12 May 2020 19:06
- loner
Replied by loner on topic How do you get a broken brake electrical cable out of a ‘74 DT360A?
RT325 and long stride are right. I just replaced one on a '81 DT 175. Small screwdriver or seal pick will do.
12 May 2020 19:34
- mrstangblb
Replied by mrstangblb on topic How do you get a broken brake electrical cable out of a ‘74 DT360A?
I don’t think I can come up from the bottom so I’ll see if I can get in with something narrow. There is a tab but I can’t see the thing.
Barry
KK4RXN
12 May 2020 20:04
They don't make it easy do they. Years since i've done one so guessing. But might need two hands, one to push it back out while trying to depress the tap with the other. Could be reluctant to be pressed as might have dirt behind the tab.
13 May 2020 04:04
- pabdt
Replied by pabdt on topic How do you get a broken brake electrical cable out of a ‘74 DT360A?
Buy a new cable so you can study how it clips in. Had the same issue with a 125. Think I ended up pushing broke connector through inside of brake caliper holder
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
- mrstangblb
Yep - I have a replacement and want to be sure not to mess anything up.
Barry
KK4RXN
15 May 2020 05:16
Replied by MarkT on topic How do you get a broken brake electrical cable out of a ‘74 DT360A?
When those break on me, it's the retainer clip and the whole thing falls out and won't stay in. It shouldn't be hard to remove with a small screwdriver or pick pushing in the tab access hole
The following user(s) Liked this Post: mdscott, mrstangblb
15 May 2020 07:03
