75 DT 250 crankshaft play
  • tlh0824
  • tlh0824's Avatar Topic Author
75 DT 250 crankshaft play was created by tlh0824
Hello
We were getting our motor back together, and unfortunately snapped a case bolt. So we took everything apart extracted the broken stud and now reassembling, and have notced a slight bit of play, pulling the crankshaft in (flywheel side). I don't remember the play the first go around. The bearing feels fine the crankshaft feels fine. I am not sure if I should try a shim, or just go with it and see how it feels when I get the other half together.
Take a look I posted a video on YouTube
10 May 2020 13:17 #1
Replied by DEET on topic 75 DT 250 crankshaft play
If that movement is in the bearing inner race, you must replace the main bearing.
If the movement is the crank snout moving in and out of the bearing inner race, either the crank journal has been reduced in size or the bearing inside diameter has been enlarged. Replace the bearing and hope for the best.
The flywheel side should "float" in and out due to expansion. It should not spin freely in the inner race.
10 May 2020 13:26 #2
  • tlh0824
Replied by tlh0824 on topic 75 DT 250 crankshaft play
Thanks Deet,
I tried another crankshaft and had the same issue.
Is there a torque setting when using a crank puller?The first go around I really cranked the hell out it, would that cause a issue?
10 May 2020 13:39 #3
I don’t think so.
It makes a difference where the movement is.
Let’s say all of the balls in the race lost 10% of their diameter. The crank would wobble, slide in and out, up and down. So.... is that what it is doing?
Or is it just the crankshaft journal moving in and out of the inner race?
10 May 2020 14:11 #4
  • tlh0824
It's just moving in and out slightly. Not all the way out and it moves in just enough so that the crank will touch the case.
10 May 2020 14:35 #5
Replied by mdscott on topic 75 DT 250 crankshaft play
DEET will guide in the right direction.
Were the bearing replaced?
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
Last edit: 10 May 2020 14:49 by mdscott.
10 May 2020 14:48 #6
  • tlh0824
Yes they are new
10 May 2020 14:55 #7
Replied by RT325 on topic 75 DT 250 crankshaft play
Its held hard against that bearing with the crank gear & nut which i can see isn't on yet. But is the play what you would get if say a C4 clearance bearing were used [guessing]. Clearance is in the race not the fit of the shaft in the bearing. But C4/C3 allows for a super tight fit like on the mag side so the inner race swells a gnats whisker. Without the crank in--can you feel play in the bearing just grabbing the inner race. Is the bearing retaining ring in the case loose the way they're cast in? Not common on those. Things like that!!.
10 May 2020 15:13 #8
  • tlh0824
It's a C3
Is that right?
10 May 2020 15:25 #9
Replied by FrankC on topic 75 DT 250 crankshaft play
I don't know much about the races or crankshaft fit. Just a question though is the crank puller your using pushing against the inner race or does it rest on the case.
Last edit: 10 May 2020 15:46 by FrankC.
10 May 2020 15:42 #10
