1974 DT250 LED Headlight conversion.
Replied by bart.ives on topic 1974 DT250 LED Headlight conversion.
Looks like you are on the right track. I went ahead and ordered the conversion housing and led bulb from Amazon. Looking forward to your success with this effort. To get high and low beams to work may have to add a rectifier and convert to DC. I have been contemplating this for a while. Good luck.
Be Happy!
The following user(s) Liked this Post: Yamalol
07 Oct 2019 04:23 #11
Replied by shyted on topic 1974 DT250 LED Headlight conversion.
Great subject,but it makes me laugh to know a push bike light is brighter than Yamahas effort.
The front light is shocking.
07 Oct 2019 12:30 #12
Found this video on how to wire Headlight from AC to DC with relay. I think this will work for this conversion to a DC LED headlight with both High and Low beams working. It is for a scooter but I think the addition of a relay to control battery power to the headlight would work. Relay AC to DC wiring
Be Happy!
Last edit: 07 Oct 2019 18:23 by bart.ives.
07 Oct 2019 18:21 #13
Replied by Makotosun on topic 1974 DT250 LED Headlight conversion.
Unfortunately the relay setup presumes you have a 12 volt system. The relay may work fine on 6 volt, but you may need a 6 volt relay.
If it works, the setup should work. It doesn’t solve the issue of the overall low output, but the 6 volt LED bulb should.
Enjoying this discussion!
08 Oct 2019 04:50 #14
Replied by MarkT on topic 1974 DT250 LED Headlight conversion.
Just FYI, all he's doing is using a relay to connect the headlight to the battery and bypassing the original AC wiring to the headlight.
Relay is not turning AC into DC.
Relays are just basically a "remote control" heavy duty switch. On the old Yamahas, powering the headlight switch from the brown wire will accomplish the same thing.
08 Oct 2019 06:09 #15
I think powering the Headlight Switch directly from the brown wire will have the Headlight and all lamps on all the time, in both the first and second on switch positions. Maybe not a desirable result. Using a relay triggered by the Blue wire and powered by the Brown wire to the switch would, I believe, leave the switch functioning as originally designed, first on position no lights, second on position lights.
Be Happy!
08 Oct 2019 07:03 #16
1974 had the on off for the headlight in the handlebar switch.
Blue wire to taillight off the switch could be used instead of brown to power LED headlight off battery on a few years of the US bikes with headlight controlled by key...
Early US bikes and "other country" bikes had the taillight powered by the headlight AC circuit so blue wire on those would not work to power DC light or even to switch relay... (US law change in about 1970 required taillight to stay on with engine off)
Using a relay is generally not a bad idea... if using a low current LED the Yamaha switches are more than capable of handling the current without the complication of a relay.
Mostly i wanted to make it clear that the relay is not "converting" AC to DC. Question is if the battery charge circuit will keep the battery charged with an LED running off the battery full time. Would have to try it and see.
:Buds
08 Oct 2019 09:46 #17
P.S. Nobody here said the relay was converting AC to DC... it was the video where the guy seemed to me to say that's what he was doing.
08 Oct 2019 09:51 #18
MarkT, yes I understand your position, thanks for the clarifications. I have a 1968 DT1-250 that uses the switch to control the lights, so not that familiar with the differences between the 68 and 74 models. When I got mine it had no lights working, several later model parts, an earlier headlight lens assembly and a wiring harness that was fractured beyond repair. Lot of other issues also. I have a H4 6volt 35w/35w bulb but still not adequate light for my old eyes. That is why I would like to get an LED bulb if it provides better lighting. Any how here is my modified wiring diagram as of now for those who might be interested.
Be Happy!
08 Oct 2019 12:26 #19
bart.ives... yes, that is the early system and the problem with a relay triggered by the blue wire is that blue everywhere on that system is "AC" and the relay will need "DC" to reliably activate it.
Slightly later models had a different key switch where only the taillight (and not instrument lights) is powered from the battery with the key in "lights on" position. The later key switch/harness would reliably run a relay off the taillight wire.
08 Oct 2019 12:52 #20
