OPEN vs SEALED bearings for rear wheels?
  • pabdt
  • pabdt's Avatar Topic Author
  • Platinum Member
  • Platinum Member
pros/cons? I'm thinking I will use the open like stock.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
11 Sep 2019 22:31 #1
Replied by JayB on topic OPEN vs SEALED bearings for rear wheels?
I use sealed bearings. They are lubricated for "life", no repacking the bearings. It is difficult for water or dirt to get in them. If they ever get loose, just replace them. Small price difference if any. I still grease the axle, seals and bearing spacer area when assembling. I keep the original or new seals in place.
Replace your brake shoes at the same time if they are old.
12 Sep 2019 04:56 #2
Replied by mdscott on topic OPEN vs SEALED bearings for rear wheels?
Ive popped the cover off sealed bearings and seen very little grease. Ive re-greased them and put the sealing cover back on.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
12 Sep 2019 08:14 #3
  • pabdt
  • Platinum Member
  • Platinum Member
Replied by pabdt on topic OPEN vs SEALED bearings for rear wheels?
limited use bike, gotta go sealed for the clean factor. Can put a little grease in there to keep the axle and seals lubed up.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
12 Sep 2019 12:25 #4
Replied by Pillsbury on topic OPEN vs SEALED bearings for rear wheels?
sealed, something other than a Chinese make if you can
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
12 Sep 2019 12:58 #5
Replied by nutt on topic OPEN vs SEALED bearings for rear wheels?
Just bought front and rear bearings local. Bearing house downtown Portland and all were in stock. Sealed Koyos which are still quality bearings. All 5 bearings and 2 seals for $74.
I'm confident they'll last as long as I do.
Popped the cover off each bearing and they all had grease, not packed, but enough. If you pop a cover and there's no grease visible, pop the opposite side off and you'll likely find it. I understand that sealed bearings have roughly a 25% pack per design.
Koyos are still made in Japan. They had others there that were China made for 1/3 the price.
And, I see no advantage for open bearings, once the contaminants get in, they won't purge themselves, so the key is to not let them in. Rub a little axle grease around the seal as you install them for a little added barrier.
Last edit: 12 Sep 2019 15:06 by nutt.
12 Sep 2019 15:01 #6
Replied by MarkT on topic OPEN vs SEALED bearings for rear wheels?
The big advantage to open is it's a little easier to clean and repack... and they might drain better than the sealed bearings if you ran through a lot of over-the-axle water crossings where a little water might get into a bearing.
12 Sep 2019 15:12 #7
A fellow Enduro/ 2-day Qualifier rider put Zerk fitting in the steering head, got tired of messing with greasing the bearings.
Thanks Mark
Roseville, Ca.
'03 ST1300
'75 Norton
'73 CB500K
'81 Honda CT110
'87 PW50
'64 McClane Edger
'65 Honda S90
12 Sep 2019 16:02 #8
Replied by KennyV on topic OPEN vs SEALED bearings for rear wheels?
There's a difference between shielded and sealed. Z / ZZ shielded one or both sides. RS / 2rs sealed one or both sides. A sealed bearing shouldn't alow water in unless it's shot and needs replacing anyway. Shield will alow water / dirt / and what ever in that will fit between the the small clearance between the shield and inner race.
A sealed bearing should not be packed full of grease. For the lubrication to work properly there needs to be air space. As Nutt said, by design I think 25% is probably correct.
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
12 Sep 2019 17:58 #9
Replied by liferbiker on topic OPEN vs SEALED bearings for rear wheels?
I like sealed no reason at all to have an open bearing these days. I too ck lube quantity, re paked very few (when new)
13 Sep 2019 00:45 #10
