Yamaha DT175 MX 1979 Throttle & Oil Cable Replacement
The cable picture on Yambits doesn't look right...  Looks like the threaded type?
78-81 DT175 monoshock uses the "slip fit, retained by clip" oil pump cable retention at the case..
Last edit: 05 May 2025 15:08 by MarkT.
05 May 2025 15:06 #11
I've never tried to "mix and match" cables...  the later 3J lower pump cable might also fit the earlier 2A6 bikes?   I've only used a complete later cable set.
(The 80-81 cable splitter is a new "self compensating" design but lower cable could possibly work with older splitter?)
05 May 2025 15:20 #12
