RS100 wiring loom
  • Welshboy
  • Welshboy's Avatar Topic Author
RS100 wiring loom was created by Welshboy
hi, hi, I'm trying to rebuild a 1978 RS100 for my wife.i was wondering if the DT100 had the same harness or anotheer bike.
i live in UK.
18 Mar 2025 07:14 #1
Replied by Gr8uncleal on topic RS100 wiring loom
 from near Salisbury, Wiltshire.
Do you have a parts manual for your bike? Also, is there anything of the original harness left?
18 Mar 2025 07:23 #2
  • Welshboy
Replied by Welshboy on topic RS100 wiring loom
Thank you.
i don't have a parts manual.
the harness is intact but when riding the voltage spikes - i have been advised the harness has oxidised.
18 Mar 2025 08:00 #3
I'm no sparky, but my first port of call would be the voltage regulator.
Treat yourself (and the missus!) to a genuine Yamaha parts manual and a genuine Yamaha service manual.
The following user(s) Liked this Post: RT325, Oldbikenut
18 Mar 2025 08:44 #4
  • Welshboy
already changed the regulator.
i will look for those manuals thank yous
18 Mar 2025 09:53 #5
I had a look at the parts list on the CMSNL site and couldn't see a regulator listed.
Admittedly, this was the US spec model, but even so...
Could you post a photo of the part you fitted? Note that you'll need to use a third party host such as Imgur to post photos. Alternatively, was it this part you fitted (rectifier)
RECTIFIER ASSY for RS100 1976 USA - order at CMSNL
or something like this?
VOLTAGE REGULATOR ASSY for DT250 1979 USA - order at CMSNL
Last edit: 18 Mar 2025 10:44 by Gr8uncleal.
18 Mar 2025 10:38 #6
Replied by MarkT on topic RS100 wiring loom
Make sure you have a good battery installed as it does provide some primitive "voltage regulation".
Are you sure you replaced a regulator and not the rectifier?  Here in the USA 100cc bikes did not have a regulator until later on.
Rectifier would have a red and a white wire.  Regulator would just have one yellow wire and case needs to be grounded.  Also, there are more than a few aftermarket one-wire AC regulators that don't work properly and will let the voltage spike.  I use Yamaha OEM...  often used ones are cheap on ebay if you look and the seller often doesn't know what it is.
18 Mar 2025 11:39 #7
I see Alan had the same idea I did.
The following user(s) Liked this Post: RT325, Gr8uncleal, Ht1kid
18 Mar 2025 11:40 #8
18 Mar 2025 12:01 #9
  • Welshboy
hi, firstly thank you for helping me.
Ihave taken my bike to an engineer who has changed everything except the harness - hence my desre for a new one.
the engineer is a motorcycle mechanic and enthusiast
19 Mar 2025 04:40 #10
