Yamaha DT2 brown sludge out of exhaust port
  • Jogar
  • Jogar's Avatar Topic Author
Howdy,
so I lost spark at some point. Used a 6v test light around on the bike, found that the last owner’s homemade ignition bracket had rattled loose and the red wire wasn’t getting power unless I gave it a little push.
so I got spark back! I also drained the carb bowl and re-cleaned it before I Tried to start er again, the pic is attached…. Not good lol. Turns out my gas tank cleaning missed a bit somewhere, terrible looking gas.
Im running the dialysis tank now (aux fuel tank )
then after putting a bit of the premix into the spark plug hole to rinse it out as someone suggested, it fired up then died. Now it fires but only runs with a touch of throttle, then dies.
wonder what to do next!
thanks guys
imgur.com/a/geY5yeu
youtube.com/shorts/sBwiWa9fZIc?si=dBW7ZS9H8ymLShfZ
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
The following user(s) Liked this Post: thumperstew
30 Mar 2026 19:51 #11
That looks like main jet, but that carb prob needs a total clean up.
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
The following user(s) Liked this Post: Jogar
30 Mar 2026 20:58 #12
  • Jogar
I’ll give the carb another clean, and make sure all the correct jets are on there and why not
While I’m in there.
I also elected to pull the jug and replace the piston / rings . It was pretty grimy in there.
1973 Yamaha RT3
1973 Yamaha CT3
1972 Yamaha DT2
1969 Yamaha AT1
1964 Honda CT200
06 Apr 2026 05:11 #13
