RT2 Frame, Does this need welding?
  • MK19
  • MK19's Avatar Topic Author
I attach some images of one of the joints in the lower part of the frame on my RT2 which I am about to send for powder coating. The right hand joint appears to be partially open whereas the left side is not. Is the appearance of the right side normal? Should I be looking to get this welded prior to powder coating?
I can see no evidence of other frame damage, no twist or torsion or evidence of a crash.
Left (normal) side
Right side
Right side
17 Feb 2024 13:56 #1
Replied by Tinkicker on topic RT2 Frame, Does this need welding?
Right side is a concern. Left side is a product of mass production tolerances.
The following user(s) Liked this Post: MK19
17 Feb 2024 15:08 #2
  • MK19
Replied by MK19 on topic RT2 Frame, Does this need welding?
Left side looks ok to me, but you think the right side is a failure of the weld?
17 Feb 2024 15:19 #3
It looks like very poor welding from the factory.  The japanese manufacturers were notorious for poor quality welding back in the 70s and 80s.  Yours happens to be the worst I have seen.
Last edit: 17 Feb 2024 22:18 by Tinkicker.
17 Feb 2024 21:53 #4
Replied by LongStride on topic RT2 Frame, Does this need welding?
Agreed, little touch up on that right side,. Tinkicker is right, some of the 70's frame welds needed touched up when new , had a similar issue with my RTMX where the weld did not penetrate
2ET703 Central Texas
18 Feb 2024 05:01 #5
  • MK19
Thanks Guys. I'll get it checked out at the welder's tomorrow.
18 Feb 2024 10:37 #6
Replied by Enduro nut on topic RT2 Frame, Does this need welding?
I just checked my 73 Rt360 that im doing and it looks better than yours. id touch up those welds if i was you.
18 Feb 2024 13:09 #7
