1973 RT3 throttle slide binding.
- pahiker
1973 RT3 throttle slide binding. was created by pahiker
Background. Removed carb, noticed bolts holding it to reed block were barely past finger tight. Cleaned carb in Berryman, replaced tiny o-ring, gasket, and corrected float height. Fair amount of debris in carb, Berryman removed it nicely. Reinstalled carb and noticed slide appeared stuck. Removed cap and tried to pull it out, but it was jammed tight. After some effort decided to remove carb and slide released when I unbolted it. After playing with it I discovered that slide binds unless bolts are barely past finger tight as when I removed it. Thought maybe carb was having an interference fit with drain plug hose at bottom of motor which may be putting torque on float bowl, but there's sufficient clearance. Fired bike up and it runs fine, but was hoping someone would have an explanation on this situation. Googled away, but no hits, only for slides stuck in the wfo position.Thanks!
1973 Yamaha RT3
2024 Suzuki DR650
2026 Yamaha Tracer 9
2024 Suzuki DR650
03 Jan 2024 12:55
Replied by MarkT on topic 1973 RT3 throttle slide binding.
Not unheard of.
Flange was probably overtightened in the past. Take carb off and check flange for warping with a straight edge.
Too thick of an o-ring on the mounting flange can also cause an issue.
The following user(s) Liked this Post: DVM, Ht1kid, LongStride, pahiker
03 Jan 2024 13:39
Replied by RT325 on topic 1973 RT3 throttle slide binding.
Yes as Mark says.
I used to file mine flat & if you're running an Oring in the groove only fit one big enough for the job, not oversize as then pulls the flange ears & sends carb body out of shape trying to compress the Oring.
The following user(s) Liked this Post: DVM, Ht1kid, pahiker
03 Jan 2024 15:40
- LongStride
Replied by LongStride on topic 1973 RT3 throttle slide binding.
Yep,.just what MarkT said, over tighten and slide sticks, use some gasoline proof sealant on the oring tighten untill sticks and back off untill it frees up, is s what it is
2ET703 Central Texas
04 Jan 2024 16:16
