CT3 turn signals slow flashing
Replied by MarkT on topic CT3 turn signals slow flashing
Only happens on left turn?
20 Jun 2023 14:29 #21
Replied by goatboy56 on topic CT3 turn signals slow flashing
On both my CT2's with the aftermarket ones both alternate on left and right hand turn.
2 - 72 CT2's
2 - 72 DT2's
2 - 73 LT3's
73 AT3
2 - 73 CT3's
73 DT3
75 DT250B
76 DT175C
20 Jun 2023 14:35 #22
  • rsmith56
  • rsmith56's Avatar Topic Author
Replied by rsmith56 on topic CT3 turn signals slow flashing
Only on the left turns. Still, it is better than it was. Once I got to the stock flasher, I tried it again. It was making a buzzing sound before it would flash. I got a little shock as I was holding it...ouch.
Last edit: 20 Jun 2023 15:18 by rsmith56.
20 Jun 2023 15:16 #23
Replied by RT325 on topic CT3 turn signals slow flashing
Bulb wattage has to match whats on the relay with the old style relays. Higher wattage=faster flash. I know nothing about new fangled ones though. Do you have bulbs matching the relay & same for left & right side.
20 Jun 2023 15:57 #24
  • rsmith56
They are original bulbs that came with the bike. Original owner had removed turn signals when new. I got them in a box, cleaned em’ up & installed. Bike had 322 original miles when I got it. I can check the bulbs, what wattage should they be?
20 Jun 2023 17:28 #25
Replied by SKYDANCER46 on topic CT3 turn signals slow flashing
rsmith56,
The original flasher has to be grounded to work or it will just make a buzzing sound and not flash if you have it in your hand. It will startle you for sure.
Here is a set up i put together that makes the turn signals work much better on these old 6v Yamaha enduros with turn signals. There brighter, flash faster then stock, more consistant, flasher makes a clicking noise simular to the original Yamaha flasher, easier on the battery, pilot light works too.
Also solves the dreaded tial light/brake light dimming issue.
If you use this complete set up you need to do some wire rearrangement in the headlight bucket and at the flasher because of the reverse polarity pilot light. Easy to do and i can explain if needed. But you can use just this flasher with your stock bulbs and it should work great. Much better then any 2 prong electronic flasher i have tried.
20 Jun 2023 18:42 #26
  • Gr8uncleal
  • Gr8uncleal's Avatar
Replied by Gr8uncleal on topic CT3 turn signals slow flashing
Likely a dodgy connection somewhere - I had the same issue on my RD125A.
Try wiggling the bulb in each left side indicator to see if this makes a difference.
21 Jun 2023 00:31 #27
Replied by Ht1kid on topic CT3 turn signals slow flashing
Skydancer yes I would like to know the instructions to use it on my CT1C it’s ridden a lot on the street Thanks
  Ps What is the brand and number on the bulbs
Last edit: 21 Jun 2023 05:11 by Ht1kid.
21 Jun 2023 04:51 #28
Hi HT1Kid,
I will start a new thread on this with the information and some pictures in the next few days. That way it can be searched by topic. Been real busy lately. I will get it on here.
21 Jun 2023 19:39 #29
Thanks I’m looking forward to it  cheers
21 Jun 2023 20:42 #30
