Ignition coil compatibility
  • Bdee
  • Bdee's Avatar Topic Author
Ignition coil compatibility was created by Bdee
I was trying to track down a problem starting my CT3.  The problem started after I swapped carbs but was not resolved by swapping them back.
In desperation I swapped out my ignition coil, an Hitachi CM61-20 for a coil used by many other Yamahas, including my 80cc Chappy, a Mitsubishi F6T401.
The starting issue didn't improve or worsen. It did, however, spark some curiosity about whether I should have even tried the Mitsubishi coil. Are the two equivalent enough that they are interchangeable on a CT3?
thanks,
Rob
Last edit: 18 Nov 2023 13:51 by Bdee. Reason: grammar
18 Nov 2023 13:50 #1
Replied by Sneezles61 on topic Ignition coil compatibility
If I can be dumb as my old grey mules… tail light..
Wasn’t Mitsubishi the ones that perfected these type of systems for aircraft?
Sneezles61
The following user(s) Liked this Post: DaveHunter
18 Nov 2023 19:04 #2
Replied by DaveHunter on topic Ignition coil compatibility
I believe there are only two methods Yamaha used for spark 50 years ago, prior to their getting into electronics
 1) 12 volt DC battery to a coil
  2) primary AC coil on the flywheel generating 50? AC volts to a secondary coil each time you kick it over
 CT uses method two so any coil designed for similar setup would likely produce a spark.
18 Nov 2023 20:32 #3
Replied by turbodan on topic Ignition coil compatibility
I once used a coil for a much later model YZ80 on a 74 360. Worked flawlessly. You may have problems trying to use an inductive type coil with CDI system or vice versa.
18 Nov 2023 20:43 #4
Replied by Drac56 on topic Ignition coil compatibility
TurboDan.
curious.. that later model coil.. hows it held up?
looking for a 2nd Coil .  Bike 2.. 1970 RT1..
18 Oct 2026 08:11 #5
