DT2 carb choke lever
- Oldskoole
DT2 carb choke lever was created by Oldskoole
I’ve got a sweet running DT2. Always cranks on the 3rd kick, cold. Here’s my question, you have to hold the choke lever down and hold it down to crank it. It won’t stay pushed down. Is this normal? If not, what’s the fix? Thanks in advance for the help!
17 Mar 2021 18:12
- Yamadude
Replied by Yamadude on topic DT2 carb choke lever
Perhaps you lost the tiny ball bearing and/or backing spring that creats a detent or stop in the choke lever arm. If so, they can be found.
You can just call me Dude.
Syracuse, New York
Syracuse, New York
The following user(s) Liked this Post: Oldskoole
17 Mar 2021 18:16
- Yamadude
......or perhaps the hold-down screw that secures the choke arm just needs to be tightened.
Syracuse, New York
Syracuse, New York
17 Mar 2021 18:18
Replied by MarkT on topic DT2 carb choke lever
There is a piece of springy steel that is bolted under the choke plunger nut... pushing the lever down makes a bump on the lever go over a bump on the spring steel arm.
View from front of carb,
arrow points to "spring steel thingy" (yes, I believe that is the official name)
The most common things are someone puts the spring steel on incorrectly, it's missing, or the easy fix is that it's moved over and no longer touches the lever. (seen that a lot)
In this side view picture, the lever L is right at the edge of spring S... loosening the choke plunger nut and centering the spring under the lever would be a good idea... but heck, it still works so I probably won't bother.
The following user(s) Liked this Post: Oldskoole, Snglsmkr, Schu
Replied by RT325 on topic DT2 carb choke lever
Exactly as Mark says. Save me typing. Not easy is it, holding it while kicking.
- Yamadude
Ah, yes, the spring steel thingy....Like my DT3... I was thinkin' of the choke arm on my '74 TY250; it has a detent with a ball bearing.
Syracuse, New York
Syracuse, New York
18 Mar 2021 07:47
