Aftermarket Stator/flywheel kits
  • edelweiss
  • edelweiss's Avatar Topic Author
Aftermarket Stator/flywheel kits was created by edelweiss
Anyone know any places where they might make a aftermarket stator/flywheel for a '74 DT250?
Thank you,
John
30 Dec 2020 05:07 #1
Replied by DT Tim on topic Aftermarket Stator/flywheel kits
I’ve just purchased one for my 400 from Rexs Autoshop, excellent quality and very easy to fit, trouble free spark from now one.
31 Dec 2020 00:40 #2
  • edelweiss
Replied by edelweiss on topic Aftermarket Stator/flywheel kits
Where is Rex’s Autoshop? Are they on the web?
Thanks!
31 Dec 2020 07:44 #3
Replied by Bigdog302 on topic Aftermarket Stator/flywheel kits
www.rexs-speedshop.com/ There is also Vape/Powerdynamo.
www.powerdynamo.biz/eng/products.htm
each has it's pros and cons, for example The vape kit comes with a new flywheel and offers 180 watts while the Speedshop version uses your old flywheel and offers 45 watts to power the headlight. the vape kit comes with a flywheel but there may be a little vibration because the flywheel is not balanced with your crankshaft but the vibration is tolerable, it won't make your hands numb or anything.
Dave
Jesus is Lord!
Last edit: 31 Dec 2020 10:07 by Bigdog302.
31 Dec 2020 09:59 #4
Rex also offers another Stator only kit that uses your old flywheel if it is stamped foto 1971.
www.rexs-speedshop.com/product/dt250-twi...th-12-volt-lighting/
Dave
Jesus is Lord!
Last edit: 31 Dec 2020 10:29 by Bigdog302.
31 Dec 2020 10:25 #5
Replied by MarkT on topic Aftermarket Stator/flywheel kits
My VAPE (Powerdynamo) kits have run smooth as glass... electric motor smooth.
In fact lack of vibration is one of the things Dave Meis commented on when riding my first DT175 with the Powerdynamo... and that engine likes to rev to 10,000+ RPM with the porting it has.
The following user(s) Liked this Post: Blackhat250
31 Dec 2020 12:02 #6
On my 400, it vibrates a little. my stock 400 is smoother than my modified DT400. of course I never rode the bike completely stock as the ignition on it had a broken pulsar and stuck piston rings. this is also the engine that has very little intake side piston skirt with the MX400B top end.
Dave
Jesus is Lord!
Last edit: 31 Dec 2020 12:59 by Bigdog302.
31 Dec 2020 12:09 #7
Replied by Wessi on topic Aftermarket Stator/flywheel kits
Very interesting tread.
I want to purchase a Vape/Powerdynamo for my ´75 DT250 , soon. Main reason fot this decision are the vibrations around 4500rpm, which i had with the previus crancshaft more intense, with the recent cranckshaft still there at same rpm. So i think, it´s the flywheel, Some hammer marks are on it and dial gauge shows on flywheel 2/10th mm non circular (within specs or damaged?)
A motorcycle specialist told me to pull the Flywheel, install a dial gauge behind the konus on the cranc and measure the roundness . Should not be more then 2/100th mm.
Didn´t measure , yet.
03 Jan 2021 04:45 #8
