DT3/RT3 Battery Box
  • Jools
  • Jools's Avatar Topic Author
DT3/RT3 Battery Box was created by Jools
I'm missing a battery box for my rebuild, haven't managed to find anything online - not even any photos but I have worked out that the At & CT are different and the DT250A
I am now looking at trying to fabricate one from sheet steel, or perhaps 3D print one.
However I need some photos of the battery box to actually work out a design that will work and fit in the restricted area available but use the original mounts. The RHS frame lug has broken off so I will need to make something up to weld back on too.
Any help with some images to assist will be greatly appreciated.
The Older I get the Better I was !
1978 TZ750E, 1991 TZ250 3YL, 1973 DT3, 1991 TZR250 3XV
1989 TZR250 3MA, 1986 TZR250 2MA, 1983 RZ350 YPVS
1981 RD250LC, 1973 RD350, 1998 YZF R1, 1993 FJ1200
26 Jun 2020 16:49 #1
Replied by 1971DT250 on topic DT3/RT3 Battery Box
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=114272587271&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • Jools
Replied by Jools on topic DT3/RT3 Battery Box
Many thanks, that image answers a lot of questions of how the mounting tabs project.
Can the box be installed from above or does it need to go in from another angle - is there enough clearance ?
27 Jun 2020 14:30 #3
  • The Crafting Rider
  • The Crafting Rider's Avatar
Replied by The Crafting Rider on topic DT3/RT3 Battery Box
it is installed from above. just drops in place.
27 Jun 2020 14:40 #4
  • Jools
I'm just going through completing all the wiring and connections, including the voltage regulator I located on the back of the rectifier mount under the tank.
All colours matched up ok, and lot of connectors required a good clean or replacing. Then I was left with just one lone orphan wire - pale blue for the neutral switch, which my engine doesn't seem to have - or if there is one its not in the normal Yamaha location on the end of the selector drum. And there are no wires from the main loom that would indicate that there is one.
So am I looking in the wrong location ? both manuals I have do show a neutral light in the wiring diagram.
Last edit: 01 Jul 2020 18:29 by Jools.
01 Jul 2020 18:28 #5
Replied by MarkT on topic DT3/RT3 Battery Box
No neutral light on the 73 250/360.
01 Jul 2020 19:42 #6
Replied by Gr8uncleal on topic DT3/RT3 Battery Box
+1
Where is this lone wire Jools and do you know its source? If it is coming from a warning light in the tacho, then you have the wrong tacho . This is not unusual and I had the same issue with my RT2.
02 Jul 2020 00:55 #7
  • Jools
Thanks for confirming that guys. Yes it does come from the tacho I think. When I was assembling missing parts back in New Zealand 20 odd years ago living in a dairy farming community, I used to rummage through the local breakers shelves looking for bits and pieces, so its not surprising - plus the red line being too high gives it away !
I can live with that for now as it will be a rolling resto and no way a show pony.
Was the DT3 generally an American market bike ? I guess some must have made it to NZ.
02 Jul 2020 14:17 #8
Replied by Swoop56 on topic DT3/RT3 Battery Box
Plenty of DT3's came to New Zealand . Not so plentiful now however .
02 Jul 2020 18:43 #9
And a handful, in slightly different spec, might have made it to mainland Europe, but not the UK. However, quite a few are now being imported from the US to the UK.
02 Jul 2020 23:53 #10
