L5TA Timing procedure?
- dmcarthur
L5TA Timing procedure? was created by dmcarthur
I am wondering if anyone has a service manual for the L5Ta. I am having trouble getting information on how to set the timing. My email is This email address is being protected from spambots. You need JavaScript enabled to view it.. Thanks.
27 Jan 2026 18:14
- pabdt
Replied by pabdt on topic L5TA Timing procedure?
manual states 1.8mm BTDC. I am not familiar w/that bike, so hopefully this is the correct link. if what I think reminds me of my 74 DT125 for timing. page 73 of manual listed in "scramblers" at legends
. L5TA Service Manual
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha DT1S 250
1969 Yamaha CT1 175
1974 Yamaha DT360A
1973 Yamaha DT3 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
- dmcarthur
Replied by dmcarthur on topic L5TA Timing procedure?
Thank you so much. I removed the stator today and am trying to figure out how the points are triggered. I do not see a cam on the shaft - strange. Any ideas?
27 Jan 2026 20:23
Replied by MarkT on topic L5TA Timing procedure?
Cam is on the "governor assembly" (advance mechanism) which is held on by the rotor bolt.
28 Jan 2026 07:58
- dmcarthur
Ok - thank you. It is strange that there is no noticeable cam on the governor assembly like on other bikes. I guess it works differently.
28 Jan 2026 09:18
There is a cam on the governor. Otherwise points wouldn't open. It's a single so the cam bump can be and is gradual.
28 Jan 2026 10:17
Replied by RT325 on topic L5TA Timing procedure?
Points breaking at 1.8mm or 72 thou btdc with advancer held open & you're good to go. Gap around 15 thou max too. I worked on those new. Good in their day!!.
28 Jan 2026 16:07
