CT1 vs CT2/3 stator/rotor parts compatibility.
  • Gr8uncleal
  • Gr8uncleal's Avatar Topic Author
My mongrel of a CT1 appears to have even more bloodlines in it!
On a previous thread I raised questions over unused double terminals on wires from the stator assembly, together with a lack of charging.
Anyway, I picked up a new lighting coil and gave this, with the bike, to my mechanic to fit (I know my limitations!). Being a bit of a stickler for fitting the correct parts, I was a little surprised when my mechanic rang yesterday and told me that the coil was the "wrong" part - too long.
I got him to send photos of the existing rotor and stator and it would appear that I have the correct rotor (F130), but a CT2/3 stator (F136). Would this combination in itself lead to my non charging issues, or are they compatible and I have a damaged part that needs investigating?
Obviously my part was right after all, just not right for my wrong stator!
Thanks.
22 Oct 2024 03:00 #1
The CT1 stator has two coils (4 poles), the CT2/3 has 3 (6 poles).  If I remember correctly, the CT1 flywheel has 4 magnets and the CT2/3 has 6.  The magnets line up with the poles of the stator coils.
As far as I know, you must use the correct flywheel that matches the stator.
DEET is the expert on this, he may answer or you might try reaching out to him.
22 Oct 2024 06:17 #2
  • Gr8uncleal
Replied by Gr8uncleal on topic CT1 vs CT2/3 stator/rotor parts compatibility.
Thanks Mark.
To this layman, that would explain my non charging issue.
I have found a CT1 stator here in the UK. I might have to replace the source coil, but that will leave me with the correct plate, two new coils (one of each) plus a CT2/3 stator to sell on.
22 Oct 2024 06:28 #3
Getting very interesting this post.
22 Oct 2024 15:51 #4
