CT-175 Engine Rebuild Check Point Please
Replied by RT325 on topic CT-175 Engine Rebuild Check Point Please
If the bearing feels ok to spin now it'll only get tighter when in the case--case compressing the outer ring. Be good to know if it says C3 on the bearing as sounds like it needs one--or a C4.
21 Sep 2022 20:29
#11
- landyr67g
Replied by landyr67g on topic CT-175 Engine Rebuild Check Point Please
Used a bearing splitter/puller and got the bearing off with no problem to the resized LH journal - which measures barely under 25mm as mentioned. Now I could read the bearing's hidden side: "Nachi 6205" (with no other marking) and on inner ring "NC". Could that may mean "CN" clearance...which is tighter than C3 or C4? I got this bearing with the double seal from a smaller vintage 2 stroke MC website and will probably ask about the choice with my shaft. Meanwhile I ordered what is specd as a C4 bearing and seal from Partzilla.
Regards,
Joe M
Regards,
Joe M
24 Sep 2022 15:23
#12
Thanks for the update. Look forward to some good news.
24 Sep 2022 15:40
#13
- Tinkicker
Replied by Tinkicker on topic CT-175 Engine Rebuild Check Point Please
Suffix NC usually denotes normal clearance. C3 and C4 are of greater internal clearance for the reasons already given, plus some limited self aligning capability.
Other suffixes you may encounter are.
Z and ZZ where one Z denotes a tin dust shield on oǹe side only and ZZ has both sides shielded.
RS and 2RS. Same as above only fitted with true rubber faced grease seals.
Replied by MarkT on topic CT-175 Engine Rebuild Check Point Please
Some of the other bearing suffix numbers you might come across are "N" which denotes a snap ring groove.
A tricky one that many miss is the transmission output bearing on some years/models is an "NX2". Again, N is snap ring. The "X2" denotes a larger chamfer on the outer edge of the bearing. (Some models had an "X1", same thing just less extra chamfer)
If you use one without the "X2" the sprocket side output shaft bearing may not press into the case all the way. Sometimes this is not an issue, sometimes it will cause the trans to be stiff and not turn freely. It can cause output shaft gear to rub on and dig into clutch side case half. Sometimes it will cause shifting issues.
You can see the NX2 in the bearing pic at the link below from Partzilla for the later DT175/DT125. Hard to find NX2 from bearing supply, usually need to buy from Yamaha.
www.partzilla.com/product/yamaha/93306-30411-00
25 Sep 2022 07:40
#15
- landyr67g
Unfortunately don't have best to report. Ordered a 41 dollar ($US) bearing from Partzilla (while noting in their website description B6205"C4". The Yamaha boxed part arrived with a Koyo "6205 21-14 08" bearing inside. Partzilla's Tech Help is ignorant about internal bearing clearances, and I can't tell on my own what this bearing is. Can anyone else decode this part?
Thanks, Joe M
Thanks, Joe M
30 Sep 2022 13:41
#16
What is stamped on the bearing itself?
30 Sep 2022 14:54
#17
- landyr67g
6205 21-14 08
It is a Koyo bearing inside a Yamaha box. Maybe the Yamaha p/n accurately correlates whats in the box but the bearing is not stamped C4 (or anything besides th above), while Partzilla describes it C4 suffix.
www.partzilla.com/catalog/yamaha/motorcy...70/ct1b/crank-piston
Very frustrating and Partizlla tech help does not even understand what any of this means....even after 3 exchanges asking the person to confer with co-workers or leadership.
I still don't even know what the other numbers mean to the right of "6205".
Thanks for any knowledge.
Joe M
Joe M
30 Sep 2022 15:38
#18
- Pete-RT1
Replied by Pete-RT1 on topic CT-175 Engine Rebuild Check Point Please
I’ve ordered the 6205 C4 bearings and others from a bearing supplier in the past (Simply Bearings), I’m in the UK. I was able to select the brand I wanted, I think it was about a quarter of the cost your bearing. If your unsure of the bearing they’ve supplied Send it back and order from a bearing supplier.
Parts list for the bike will have bearing code and clearance.
Just my opinion, hope you get it all back together
Yamaha CT3 (in bits)
30 Sep 2022 16:53
#19
Here's a link to Koyo bearing nomenclature. See page 3.
jtkmarketing.s3.amazonaws.com/filer_publ...menclature_guide.pdf
Numbers you see are probably date code.
Sometimes clearance code C3 or C4 is stamped on edge of inner race. Check both sides of bearing though markings are usually on one side.
I'd return the one you got to partzilla and go to a bearing supply as suggested.
I've had good luck several times with All Balls # 24-1073. Currently about $40 shipped on ebay. You get both crank bearings and two OEM quality double-lip crank seals. The last set I bought had Koyo bearings with C3 or C4 clearance bearings... can't remember.
24-1073 kit will fit all the Yamaha Enduros 175's from 69-81. They could change their part sources so can't guarantee they still supply the same parts in kit. The three or four I've used were great quality every time.
30 Sep 2022 18:19
#20
