360 piston markings
- Savage Syd
360 piston markings was created by Savage Syd
I'm helping a friend re commission his 7k miles from new RT1 360 and I'm having trouble deciphering the numbers on top of his piston. On the exhaust side next to the arrow it is stamped 75, on the intake side stamped 96. If I have to borrow a bore guage or calipers I will but curious if someone can tell me what the numbers mean. I did read here that 96 means 79.96 but what of the 75? Thanks!
10 May 2021 00:32
Replied by Gr8uncleal on topic 360 piston markings
My initial thought is that 75, or .75, means third oversize - Yamaha oversizes go up in 0.25mm increments, but aftermarket (eg Wiseco) are different. I'm not sure that I'd expect to see a third oversize piston on such a relatively low mileage bike, though.
A good, clear photo of the markings would be great!
10 May 2021 01:56
- Savage Syd
Replied by Savage Syd on topic 360 piston markings
Here's the pic I took today. Had to scrape the carbon off to get it, and still not very clear, but here it is. Also I read here of a 360 piston with 74 next to the arrow and 96 at the intake but no clear answer was given on that. Very mysterious..
10 May 2021 02:42
- Pete-RT1
Replied by Pete-RT1 on topic 360 piston markings
96 is the standard size piston.
You're probably right in your assumption that the 96 relates to the 79.96mm size of the standard piston, it's also the last two digits of the standard part numbers on pistons.
As Alan says they come in 0.25mm increments after that.
Yamaha CT3 (in bits)
10 May 2021 04:00
- Jmckinney
Replied by Jmckinney on topic 360 piston markings
This is is from my DT360 after a little clean up. I’ve got a 72 and 96 stamped on the head. Please advise again what the 72 and 96 indicate?
14 Jun 2022 19:10
Replied by MarkT on topic 360 piston markings
Jmckinney.... Have you checked your VIN? Has piston been swapped?
That doesn't look like an original 74 DT360 piston?
Maybe an expert will know.
14 Jun 2022 20:51
- Enduronut
- Founder Moderator
Replied by Enduronut on topic 360 piston markings
Yes . . . from what I can see, I have no reason to doubt that's the original "standard size" DT360 piston.
If you plan on having it bored, and have trouble finding the proper oversize piston, let me know . . . I have some.
I'll be out of town until Saturday afternoon though.
14 Jun 2022 22:23
Thanks Enduronut. On my phone I couldn't see the "step" for the dykes top ring.
15 Jun 2022 05:46
- jclaassen
Replied by jclaassen on topic 360 piston markings
looking for help with 1973 mx 360 piston, like 81.5mm, my single ring piston has a 1.0 on top, measures around 81mm .sounds like enduronut could help Thanks
18 Jun 2022 17:18
Replied by RT325 on topic 360 piston markings
RT1 won't have a Dykes top ring, just two thick rings, thicker than normal. Or am i am the wrong planet again. Whats the subject.
18 Jun 2022 20:24
