Found a part in carb, please help me ID!
Replied by MarkT on topic Found a part in carb, please help me ID!
Yes, that pin keeps the needle jet from rotating and the open end of the shroud sticking up into the airflow facing forward.
12 Apr 2021 17:56 #11
Replied by Mothersbaugh on topic Found a part in carb, please help me ID!
But to be absolutely clear, that's not the pin which we were originally talking about, right? The pin 71DT250 first mentioned is the pin in the barrel, which fits into the groove in the slide. Just so we don't confuse someone still thinking about that pin...
Or am I confusing this with another thread? But rereading 71DT250's post right out of the shoot, I think we were talking about the slide in the barrel.
Last edit: 12 Apr 2021 18:52 by Mothersbaugh.
12 Apr 2021 18:50 #12
Replied by Swoop56 on topic Found a part in carb, please help me ID!
It might be a good idea to remove the needle jet while you
tap it in . In case it has turned whilst locating pin was out .
You could just remove the setter , and you'd see if the locating
slot in the needle jet still aligned with the pin .
12 Apr 2021 19:34 #13
  • msavitt
  • msavitt's Avatar Topic Author
Replied by msavitt on topic Found a part in carb, please help me ID!
saved from a huge read - thanks!
Mr Mothersbaugh - this is in fact was the subject pin, which some helpful nice person suggested could be the slide locator...but then again I cannot remember what I had for breakfast or how many drinks I had tonight.  It is not slide locator,  mine still there and is shaped like the cross section of a cylinder with hemispherical ends. Would really suck for engine to eat this up, I bet the clever Japanese engineers have it pressed in from the outside since it appears to have a flange
It's def the "jet, needle jet" locator, I am going to blow this thing out real good again, check everything again and keep whack a moleing
thanks all
12 Apr 2021 19:49 #14
To add to what Swoop said, the only time I saw one of those come out was when someone (
don't ask who
) accidentally had the jet rotated backwards and tapped hammered it into place with a hammer and a hardwood dowel.
It was a long time ago but I think I ruined that carb.
12 Apr 2021 21:00 #15
Thanks! I just didn't want someone who had never been in a carb before to get confused...
Last edit: 12 Apr 2021 21:22 by Mothersbaugh.
12 Apr 2021 21:21 #16
  • msavitt
I am blaming the previous owner!
13 Apr 2021 08:10 #17
I think we have a special thread for roastng PO's. Let me see if I can dig it up, as I have two posts qued up and ready to go!
13 Apr 2021 09:43 #18
  • msavitt
while I fancy myself as a relatively competent mechanic, I did have an "issue" removing the jet, needle jet and did tap it ever so gently in the wrong direction.  Still runs out of gas at any speed without choke so back to the bench, this time maybe without a drink.
I will spare you the clutch issue, which clearly was PO related
13 Apr 2021 10:47 #19
