Found a part in carb, please help me ID!
- msavitt
- Topic Author
Found a part in carb, please help me ID! was created by msavitt
DT1E started on 2nd kick but I have a long punch list!
one issue is that bike runs on choke, dies from starvation when it's flipped off.
supply to carb robust so this plus a full float bowl eliminates supply.
took apart thinking I need to blow things out again, despite already making things really clean and found this little bit in bowl. It's brass, cylindrical, no threads or screw head so maybe a passage plug? Measures 0.165" in length and 0.082" in diameter on one end and 0.065 in diameter on other end. Any ideas where is came from, what it does, where it goes massively appreciated!
12 Apr 2021 13:19
- 1971DT250
Replied by 1971DT250 on topic Found a part in carb, please help me ID!
Looks like the locating pin from the carb body that keeps the slide properly oriented.
12 Apr 2021 14:14
- bart.ives
Replied by bart.ives on topic Found a part in carb, please help me ID!
Yes it could be the slide locating pin, but how would it ever end up in the float bowl?
Be Happy!
12 Apr 2021 14:28
- Mothersbaugh
Replied by Mothersbaugh on topic Found a part in carb, please help me ID!
If it runs with the choke on, but dies when you push the choke in (off), that indicates a lean condition. Need more gas to run equals larger pilot. Or another cleaning of the pilot and the idle circuits.
- 1971DT250
- bart.ives
I believe the choke is a seperate delivery passage. Here is a diagram.I believe the choke is a seperate delivery passage. Here is a diagram.
Be Happy!
12 Apr 2021 14:59
- msavitt
- Topic Author
Replied by msavitt on topic Found a part in carb, please help me ID!
thank you all!
it was def in the bowl and not there when I put things together
I will take a closer look now, will figure out and report back
12 Apr 2021 15:05
- msavitt
- Topic Author
I think I found it
Can someone tell me if they have a plug in this area of similar carb before I tap it in?
thank you
I think I found it
thank you
thank you
I think I found it
thank you
12 Apr 2021 15:13
- bart.ives
You might find your answer in one of these guides.
Be Happy!
12 Apr 2021 15:13
This message has attachments files.
- 1971DT250
Here is one of mine. Looks like a brass pin is pressed in.
