Re:Just got a new project
- Mothersbaugh
Replied by Mothersbaugh on topic Re:Just got a new project
Capt Dave in Robles CA was selling some for a while there. I haven't been around for 8 mos or so. Is Capt. Dave still with us on the forum?
08 Apr 2020 10:39
#41
- Godlygaz
- Topic Author
Replied by Godlygaz on topic Re:Just got a new project
Ok so here's the trick... I was told to NOT put anything behind the bolt for it to resemble to official tool.
The trick: use the M10 bolt do it up tight then smack it with the biggest hammer you can find and smack it as hard as you can ( way harder than I was comfortable) and it pops right off
Sent from my POCOPHONE F1 using Tapatalk
09 Apr 2020 02:00
#42
- Godlygaz
- Topic Author
Where I currently am..... This scary bits now!
11 Apr 2020 00:14
#43
Replied by RT325 on topic Re:Just got a new project
Have my puller bolt somewhere but its cold outside--well not really but i'm sitting in front of the fire. Oh, ok then i'll go & get cold.
11 Apr 2020 00:35
#44
``10x1.25 pitch.
Nose bit is 31mm long & 5.5mm diameter. 10mm bit is 87mm long. I think the nose bit bottoms out in the hole so the 100mm bit doesn't contact the end of the taper. I think a 10mm 1.25 pitch good tensile strength bolt would still do the job ok pushing on the end of the shaft if you were stuck but i'd taper the first few threads a little to avoid a problem when you smack the bolt after tightening as might try & swell the end of the bolt then be difficult to wind out without a fight.
- Godlygaz
- Topic Author
You have a very rare item there!!
11 Apr 2020 11:19
#46
- shyted
Replied by shyted on topic Re:Just got a new project
Are they high impact safety socks you 've got on there ?
The following user(s) Liked this Post: Mothersbaugh, KennyV
11 Apr 2020 15:44
#47
- Godlygaz
- Topic Author
Doesn't look like mine has a circlip on the short pin here.... Is this normal ?
13 Apr 2020 06:34
#48
- Godlygaz
- Topic Author
The reason I ask is that I cannot for the life of me get 5th gear to kick ick but it doesn't look anatomically possible from the drum selector?
It's goes 1-N-2-3-4
Surly that doesn't constitute a 5 gear transmission?
It's goes 1-N-2-3-4
13 Apr 2020 07:50
#49
- Godlygaz
- Topic Author
To add pain to the already painful situations.
After a combined wait of 2.5 months ordering not one but 2 clutch baskets from the USA. Both of which have turned up broken.
Anyone by chance have one in the UK?
06 May 2020 04:14
#50
