Straight cut drive gears
Replied by MarkT on topic Straight cut drive gears
High RPM is easy on the gear teeth in terms of strength. The faster the gear is spinning, the more HP the teeth can handle.
Curious if you used to run ATF? I know a lot of people use and recommend it but my experience is excessive gear wear in a bike trans.
12 Dec 2019 16:44
#11
- Pillsbury
Replied by Pillsbury on topic Straight cut drive gears
I do not run ATF in trannys, I was running Valvoline R 30. I'm not the only one that has had problems with the 1st year gears
It seems like I was the only one running Dino oil, most use synthetic.
1970 DT1-C Street tracker
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1966 Triumph Tiger Cub
1947 Mustang
1974 Suzuki TC185
1968 Honda CL90
1973 Honda CR250
1974 Honda MR-50
1947 Mustang
1974 Suzuki TC185
13 Dec 2019 05:59
#12
- jcarr
Replied by jcarr on topic Straight cut drive gears
Sort of related,
how important is it to use a shielded bearing next to first gear, Looks like it keeps oil on the gear side and helps with first gear lube.
I got a set of generic bearings from the Buzzard and it came with an unshielded bearing.
15 Jan 2020 20:42
#13
Which model? Behind the clutch? There are Yamaha service bulletins for some models warning that a) the shield is critical and b) the shield needs to be installed a on the "outside" or the bearing will be starved for oil.
16 Jan 2020 06:23
#14
- jcarr
That's the one behind the clutch, for a DT1-f.
Thanks for the confirmation.
16 Jan 2020 13:33
#15
DT1f is a serial number... not the model... probably a DT2 or DT3? Some models have a "retainer plate" that screws on to the case and over the bearing and acts as a shield...
If yours doesn't, then best to use the shielded bearing. And good catch noticing the shield was missing!
16 Jan 2020 14:51
#16
- eschrader
Replied by eschrader on topic Straight cut drive gears
I just found my dad's old straight cut gear in one of the garage bins. Unfortunately I didn't see the smaller crank gear but I'll keep looking. My dad took them out due to stress on the cases.
How much are they worth if I find the other smaller gear? I'm restoring his old WR 500 and well the build is getting pricey so I figure I'll sell some stock piled parts I'm not planning on using.
-Eric
-Eric
-Eric
-Eric
- Mark350
Replied by Mark350 on topic Straight cut drive gears
Are you saying the rusty gear in the above picture is the clutch basket gear, looks too small and just wrong configuration? I would think straight cuts gears would impart less stress on the case as helica's place a side load on bushings, bearings transferred to the case?
24 Jun 2026 18:57
#18
Replied by RT325 on topic Straight cut drive gears
Very interesting what shows up from time to time.
YZ250A & B--which were variations of the DT1 looking motors, had straight cut primary gears but no built in cushioning in the basket, just riveted up solid.
I used a set of those straight cut primary gears with basket in one of my DT1 modified motors.
If it was something aftermarket man it'd be spinning the trans fast & need a big crank gear to match.
No provision for the kick gear to dog into there either.
Looks mighty like this one below. Can you think of any reason why it might be?
Click to the right a couple in the pics.
www.moto-gears.com/suzuki-tr750-transmission/
The following user(s) Liked this Post: MarkT, Snglsmkr, Ht1kid
