Fork seal replacement & spring removal
Hello, I am replacing the seals on my 79 MX100F and discovered an issue removing the spring. The plug/thick retaining washer on the top of the fork, just above the spring will not move. Do I need the special spring removing tool to remove this retaining washer or are there other methods that work ? When I try to depress it to push it in further in it does not move, so something is holding it.
10 Nov 2026 08:14 #1
