YZ125X AIR FORK seal replacement
Replied by RT325 on topic YZ125X AIR FORK seal replacement
I'm just waffling without being there but would've thought with damper bolt removed the fork stantion would fall out. Parts pic doesn't show a bottom bush on the stanchion. If the Allen bolt is just revolving you'd need a special tool to lock the damper or come up with a plan. They're a bugger to keep turning when removing plus tightening. I'm totaly guessing but the washer you mention is likely just sitting there to save the seal from the screw ring so might just fall out if ya lucky. I've heard of guys hydraulicing them out. Just fill with oil then compress. Stand back she could blow---!!. Just thinking if there 'is' a bottom bush & with damper free, the bottom bush would pull the seal out by holding the lower part in the vice somehow then pull hard on the stantion topping it out with bush hard up against seal. Then again i talk rubbish sometimes lol.
16 Apr 2025 04:04
#11
- Murph
Replied by Murph on topic YZ125X AIR FORK seal replacement
I made a long tool to hold the guts in the fork from spinning when turning the allen bolt. All apart now, just need to get the oil seal out, bit of a pain. Looking at heat, fire and possible dremel. The bottom bush is not fat enough to pull out the seal. It just came straight out.
17 Apr 2025 02:45
#12
I've seen interesting ideas on youtube. But yours is very recessed from what i saw. I've been lucky I guess over the years to just get a screwdriver & tap the top of the seal away from the edge & get it to sort of collapse inwards which gets it off the wall then hook it out. Direct heat can discolor the clear coating on the alloy if it still exists. Not sure about maybe boiling water. I wonder if a reverse jaw bearing puller hooked under the lip with a slide hammer attached. Or offset washers on a small slide hammer to get down under then swing them out under the seal lip. I'm sure you'll sort it.
17 Apr 2025 03:56
#13
- Murph
Seal 1 out. Heated the top of the tube with my kitchen blow torch. Creme Catalan will never be the same again.
Then set fire to the seal. Now for number 2.
17 Apr 2025 04:06
#14
- Grussell
Replied by Grussell on topic YZ125X AIR FORK seal replacement
Well I am late to the game. Murph, how is the 125x going. I have two I rebuilt including the forks.
1978 DT400
1975 DT250
1976 YZ125X - my post vintage race bike
2022 KTM 300XCW - my race bike
1975 DT250
- Murph
Hi Grussell, almost finished. Just got to repair and mod the exhaust to fit my Noguchi 175 barrel. Yeh, that was a bonus find. It's been a year of searching for bits and Mark has been a godsend.
22 Nov 2025 03:38
#16
