1981 Mx 175 coil
  • Coopsie
  • Coopsie's Avatar Topic Author
1981 Mx 175 coil was created by Coopsie
Hi there I got a 1981 Mx 175 I’m doing ohm test on the coil. The primary test I got 01.0 and the secondary test for the lead is 11.00k ohms ?
01 Jan 2025 12:35 #1
Replied by MarkT on topic 1981 Mx 175 coil
Welcome!
If you say that's the readings you got, then I guess that's what they are?
Or are you asking what they should be?  If so, the 1978 or later DT175 manual in the Tech Library will have the specs and test procedure.
That MX model is a stripped down DT...  but unfortunately the stator and flywheel used are not the same or as reliable as the DT175 versions.  4 out of 5 of the (79-81) MX175 stators I've worked on have been bad.  I've never come across a bad one on the DT version and I've worked on dozens more DT175's.
The following user(s) Liked this Post: Badrul
01 Jan 2025 14:17 #2
