74 125A gearbox leak
- Youngdrakeo
74 125A gearbox leak was created by Youngdrakeo
Hi guys
my yz125A has alot of play on the gear lever shaft.(herd it was common on the firsr models?
Which then creates a good gap between the gear lever oil seal and the shaft.
unless it has the wrong size seal in there. But im guessing its more of worn bush or somthing behind that case cover? Has anyone found a fix?
thanks
thanks
73 CT3 modified, 74 AG175 MX, 79 YB100 x2 , 79 GT 80 ,2015 ducati scrambler ,honda CT70
18 Apr 2023 11:07
- Mfguilbault
Replied by Mfguilbault on topic 74 125A gearbox leak
uxcell Sleeve Bearing 12mm Bore x... www.amazon.com/dp/B07SNV74HR?ref=ppx_pop_mob_ap_share
18 Apr 2023 12:51
- Youngdrakeo
Replied by Youngdrakeo on topic 74 125A gearbox leak
Where does that bush go ? Into the main cases?
www.yamahapartshouse.com/oemparts/a/yam/...1/shifter-2-yz125a-b
18 Apr 2023 13:19
Replied by MarkT on topic 74 125A gearbox leak
Under the cover is a seal for the actual shaft coming out of the cases. That seal has to go bad if it's leaking trans oil at shift lever. I've never seen any "wobble" where the shaft comes out of center cases so a new seal should stop the leak.
(There is a seal at the shift lever... but if leaking oil the other seal in case must be bad.)
That said, the wobble at the shifter might need a new cover and maybe a bushing in the blind hole in the case if really bad. Covers used to be readily available... haven't bought one in a few years. (Just checked, actually still is available from Yamaha, look for it in the "crankcase" section of the parts diagrams)
18 Apr 2023 14:06
Replied by RT325 on topic 74 125A gearbox leak
That first shaft is only short going to a sort of linkage. That little cover is packed with grease but wear out terrible [not a good system]. When all that is off you'll "see the next seal sealing change shaft into the transmission". Can we see the complete bike please. Is it the model with straps holding the tank on [had one of those].
- Youngdrakeo
I will pull it apart. Order seals and see if i bush can put machined into that first cover.
its got replacement main cases so doesnt have number stamped. And its running a mx125 cylinder..
i do have a new ome 125c cylinder i could use if needed.
was cheap and has a receipt for a rebuilt gearbox.
19 Apr 2023 11:06
Also, someone may have completely left out the seal that goes around the shaft coming out of the center case.
I've seen that before. My guess is previous owner sees the seal on the cover and doesn't even realize or remember there was a seal on the shaft coming out of cases. Seal in cover just keeps grit and water out of linkage under cover which should be greased as RT325 said.
Seal on shaft coming out of cases is what keeps oil in the trans.
19 Apr 2023 11:19
Youngdrakeo this is the model i was thinking. Same gearchange setup but the expensive limited number model. Then they bought out a model everyone could afford.
- Youngdrakeo
Thats it mate.
I took apart the cover and now see what you guys wore talking about.. and now see the leaking seal.. thanks guys
24 Apr 2023 20:07
