Yet another DT400 project,the Super DT400.
Replied by bluntz465 on topic Yet another DT400 project,the Super DT400.
Don't melt it!
I have been thinking of experimenting for a way to increase piston cooling.I wonder if anyone has tried to cross drill their piston like a brake rotor? I know it will not help for combustion temps,but should reduce the friction significantly You could of course run methanol for chemical cooling of the combustion.
1982 Yamaha IT465J
04 Sep 2015 16:44 #121
  • Bigdog302
  • Bigdog302's Avatar Topic Author
  • Platinum Member
  • Platinum Member
Replied by Bigdog302 on topic Yet another DT400 project,the Super DT400.
I don't plan on it. BTW I think I found the reason for the ticking noise. the nut for the primary side drive pinion was backing off. the threads are weak in that area. it backed off to the point it locked the engine up! :Blue inside the engine otherwise was great. I did torque the nut but had the impression the threads were weak to begin with.
not sure if I will hunt for another engine to rob the crank out of or get this one rebuilt. I found a NOS crank half with what I need but it is not cheap! I found a whole 1975 DT400 engine for much less.
for now I got it back together but I am leery of that crankshaft. the torque spec was 50-65 ft lbs. I got it to hold at 40 Ft lbs of torque on the nut.
when the nut backed off and it stripped the threads on the crank as the nut butted up to the side cover a little at the end. I was majorly bummed out by this. pulling the head and inspecting the top end still looks beautiful and it is getting plenty of oil.
it got really noisy as it was idling then quit. glad I was not out riding it or anything,I was testing a silencer I put on it. need to weld a stinger back on the pipe to use the silencer.
for now I got the engine back together but have not run it yet. everything else in the engine is fine,main bearings,piston and cylinder still look great and it looks like it was burning nice and fat,plenty of oil and nothing at all burned up.
when the engine stuck I was freaking about it to say the least. the engine now since the nut was addressed turns over well and very smooth.
sorry I did not take pictures and I was a most unhappy man when I tore it down to look at it.
as far as temps when running,it did not get hot but it does run a little warm. of course it was hot and nasty humid as weather goes.
BTW,I did some more reading up on the MX400B. they confirmed my findings on power pretty much,lots of power and torque and it makes mucho torque at low rpm.
scroll down the page and you will find 2 MX400B tests there. the dyno tests confirmed what another test said in their dyno test. 38 HP at 8,000 rpm. for a engine that winds like this one does. it makes
excellent bottom end power. if you scroll up the page there is a 1976 YZ400C test and in the MX400B test,the MX400 actually made more power! the YZ only had 34 hp and the MX400B made 38. the test on the YZ400C actually blamed the silencer for the power loss and they mentioned piston life in a MX400B was pretty short. the tests in question is in the link.
I was scratching my head on the YZ400C test,awfully weak power,especially considering the YZ360 made around 39 hp but it was a lot harder to ride due to it's light switch power.
vintageyzinfo.tripod.com/
Dave
Jesus is Lord!
The following user(s) Liked this Post: bluntz465
Last edit: 04 Sep 2015 20:18 by Bigdog302.
04 Sep 2015 19:55 #122
Glad you at least saved most of it,When we raced these things we usually did a teardown and inspection after every event sometimes we raced one sat and another sunday so may just do a slight inspect after sat night.There was always something to be tightened even though we used Locktite on almost everything,turning 8-9k will loosen anything.
1982 Yamaha IT465J
06 Sep 2015 14:43 #123
  • Bigdog302
  • Platinum Member
  • Platinum Member
Dave
Jesus is Lord!
10 Sep 2015 14:37 #124
  • Bigdog302
  • Platinum Member
  • Platinum Member
first we open up the instrument we are putting the new gauge face on. I wrap some abrasion proof electrical tape to protect the chrome on the instrument then work it open with a straight blade screwdriver.
then remove the needle carefully then the gauge face.
then remove the old gauge face decal. I used a wire wheel very lightly on it.
Dave
Jesus is Lord!
10 Sep 2015 14:45 #125
  • Bigdog302
  • Platinum Member
  • Platinum Member
then spray some soapy water on the gauge face backing and align the decal then used something to squeegee the water out once you got the decal where you want it.
then take a exacto knife and trim out the holes for the light bezels to go into. do it from the back and use the gauge face backing as a template.
once the holes are trimmed then you can glue the light bezels back into place followed by the rubber cups around the light bezels on the backside of the gauge face. then you can install it back into the gauge can.
I got some 12 volt LED bulbs to go into the instruments.
Dave
Jesus is Lord!
10 Sep 2015 14:54 #126
  • Bigdog302
  • Platinum Member
  • Platinum Member
Rendering Error in layout Message/Item: fopen(http://open.api.ebay.com/shopping?callname=GetSingleItem&appid=makotosu-08bc-47da-8e7d-68e3ee6e51ca&siteid=0&responseencoding=JSON&ItemID=191226911235&version=889&trackingid=&trackingpartnercode=9): failed to open stream: php_network_getaddresses: getaddrinfo failed: Name or service not known. Please enable debug mode for more information.
  • Bigdog302
  • Platinum Member
  • Platinum Member
I got to tone them down a bit. where the bulb is it overpowers the area a bit but it does illuminate the entire gauge face but it really lights up the area where the bulb is. the light is too focused in that area.
I repeated the same procedure on the speedometer. this area is easier than the tach. I also got a gas cap,seat latch and ignition switch that shares the same key.
also got the speedometer cable. it came from Rusty riders on Ebay.
Dave
Jesus is Lord!
10 Sep 2015 15:04 #128
Replied by FrankC on topic Yet another DT400 project,the Super DT400.
You might be able to spray paint a light blocking hood on the ends of the bulb so the light won't be so pronounced at the tips.
11 Sep 2015 10:42 #129
  • Bigdog302
  • Platinum Member
  • Platinum Member
I may need to do what you suggested to all the bulbs. it overpowers the indicator light bezels too. thanks for the suggestion! :OnFire
Dave
Jesus is Lord!
11 Sep 2015 11:32 #130
