New forum member with Yamaha 80 (?) Questions
Replied by MarkT on topic New forum member with Yamaha 80 (?) Questions
You'll need to split the cases.
I wouldn't call that damage "common" but I've seen it a few times.
Check the small kick start gear on the back of the clutch. That's the most common one to let go and it could take the idler shaft with it.
My guess is 20 and 21 are outside.
25 Jun 2025 17:44
#31
- ZTatZAU
Replied by ZTatZAU on topic New forum member with Yamaha 80 (?) Questions
^^^ Thanks Mark!
Yep! I'm reluctantly committed to opening the cases
When you've seen broken shafts like this, did the cases survive?
I wondered about the kicker gear on the back of the clutch. So much so that I took a picture of it because half of each tooth appeared to be ground off. Then I saw some similar pics of supposedly good clutch hubs and all the teeth looked the same as mine...
Maybe not perfect but surely serviceable to my untrained eye.
The idler gear looked much worse...
I have another on the way.
My guess was 20 & 21 as well.
I appreciate your reply! ZT
1971 K1 CB750, 1973 XLH1000, 1974 GTMXA, 1989 GL1500, 2008 FXDWG
When the starter gear on the clutch goes, generally it explodes. Which may have happened and has been replaced? Doesn't matter though.
The unknown is the needle bearing that supports the output shaft... Since you've been riding it so much as a kid, hopefully that's a sign that it's okay. If the needle bearing grenades or seizes it sometimes ruins the hole in the case.
25 Jun 2025 19:51
#33
- ZTatZAU
@MarkT said, "The unknown is the needle bearing that supports the output shaft... Since you've been riding it so much as a kid, hopefully that's a sign that it's okay. If the needle bearing grenades or seizes it sometimes ruins the hole in the case."
I've wondered about that needle bearing after seeing it in the tranny cross section diagram... because from the broken end, it looks like just a simple bushing that's exposed. Is there a separate bushing outboard of this Drive Axle needle bearing?
I can't find a needle bearing or a bushing on either of those tranny cross-section or parts diagrams. I couldn't find either on the case parts diagram either. Can anyone tell me where I can find and identify part numbers for the needle bearing and/or bushing?
Thanks1 ZT
Thanks1 ZT
26 Jun 2025 05:57
#34
I don't see either of the trans needle bearings in the parts diagrams either. (Input shaft should have one too)
It's possible Yamaha used bushings but I don't know enough about the little GT to know for sure and the engineering drawings do show needle bearings.
I will look around some more and see if I can find anything. If not, a bearing supply should be able to come up with one with the ID, OD, and length. Yamaha tended to use standard sized bearings.
26 Jun 2025 13:26
#35
- ZTatZAU
Thanks Mark!
I'll know soon enough what's in there. And I might wind up being the go-to-guy for GT80 info by the time I'm done.
ZT
ZT
26 Jun 2025 15:06
#36
Kevin aka "Mini Enduro Man" is an expert on the little bikes. I haven't seen him here for a while but you might try contacting him if you have any questions
yamaha-enduros.com/index.php/user-contro...ni+Enduro+Man?back=1
26 Jun 2025 15:17
#37
- ZTatZAU
Thanks Mark!
I just may do that.
ZT
I just may do that.
ZT
26 Jun 2025 18:13
#38
Replied by RT325 on topic New forum member with Yamaha 80 (?) Questions
Bush shows here on the inside in the link just scroll the page.
www.thumpertalk.com/forums/topic/1353989...ine-parts-reference/
The following user(s) Liked this Post: MarkT, Schu, Ht1kid, Tinkicker, ZTatZAU
26 Jun 2025 21:45
#39
Nice find RT325!!
26 Jun 2025 22:53
#40
