Autolube Pump leaking
Replied by MarkT on topic Autolube Pump leaking
You don't need to remove the clutch cover to remove the pump on any model I can think of.
Seal part numbers have been posted on the forum, you can buy them from Yamaha or DEET.
HVC cycle and others might still sell "kits" but you can probably have DEET rebuild it for not much more than a "kit"... which which is just seals and gaskets usually available from Yamaha or DEET.
Sending pump to DEET is worth it unless you simply must do it yourself... easy to mess them up so read up and be careful of losing the plungers if you decide to do it yourself.
The following user(s) Liked this Post: JimA
09 Feb 2022 18:22
#11
- lolipop50
Replied by lolipop50 on topic Autolube Pump leaking
Thanks for the pump info Mark T.
If I want DEET to rebuild the pump do I contact him through the forum?
I'm fairly new to the forum so contact info is appreciated
. Thanks again.
10 Feb 2022 06:07
#12
yamaha@nc(dot)rr(dot)com
of course replace (dot) with a .
10 Feb 2022 06:11
#13
- lolipop50
?? tried that address both ways, neither one works.
10 Feb 2022 06:58
#14
Replied by Gr8uncleal on topic Autolube Pump leaking
See attachment.
10 Feb 2022 07:19
#15
- lolipop50
Thanks!
10 Feb 2022 07:35
#16
