Headlights
  • dbwarn41
  • dbwarn41's Avatar Topic Author
Headlights was created by dbwarn41
Does anybody know of a reasonable source for 6 volt sealed beam headlights. J&P doesn't have any and they don't know when they will........
29 Aug 2015 14:03 #1
Replied by Makotosun on topic Headlights
Describe Reasonable.
Pobit on Ebay has some I think, but they go upwards of $30. You can also go with an H-4 converter unit and get 6 volt h-4 bulbs, but they usually need to be from the UK. You want 6 volt-30/30 watt or 35/35 watt
29 Aug 2015 14:07 #2
Pobit's offering:
What you need is a 4020 sealed beam unit. Hard to find, but that is the part. Wagner was the last brand I could find.
29 Aug 2015 14:08 #3
Replied by Bigdog302 on topic Headlights
if you live close to a rural area,there is usually a Tractor Supply store there and they often stock the 6 volt 5 3/4" headlight sealed beam bulbs.
I had been using the H4 6 volt bulbs in the 5 3/4" headlight on my RT1B and it does a great job for a 6 volt headlight.
it is the 35/35 watt H4 bulbs you can find on Ebay.
these guys are based in California.
from the same seller they have the H4 headlight that can be used but this one comes with a 60/55 watt 6 volt bulb. your magneto will not pull this well so ask the seller if they can substitute the 60/55 watt bulb for a 35/35 watt 6 volt bulb. I bet they can and it never hurts to ask.
Dave
Jesus is Lord!
Last edit: 29 Aug 2015 19:31 by Bigdog302.
29 Aug 2015 19:31 #4
Replied by rt31973 on topic Headlights
These are a very good buy for NOS. Not advertised NOS but I bought one and it is. He only has 4 left.
1973 RT3 360 x 2
“Happiness is an RT3 ride on a sunny day.”
30 Aug 2015 04:11 #5
Those are the real deal there with the proper original mounts. If you have a bike with that type of mount ring that is a better way to go, though expensive compared to a standard bulb. He is correct in that it is a good price for the NOS version of a hard to find part.
The following user(s) Liked this Post: dbwarn41
30 Aug 2015 04:38 #6
this part comes out of Indonesia and it is made to where you can use a standard 5 3/4" headlight on your 1968 to 1973 250 or 360 and possibly the 125/175 as well.
this is what I am using on my RT1B to mount a H4 headlight assembly. this works on sealed beam and non sealed beam 5 3/4" headlight assemblies.
Dave
Jesus is Lord!
30 Aug 2015 10:35 #7
  • dbwarn41
Replied by dbwarn41 on topic Headlights
Reasonable: ... a sense of value as opposed to a sense of worth ....
But thank you! I need several, but as it turns out one or two are the semi-sealed type so I need to do some more research.
01 Sep 2015 07:21 #8
Replied by dnaj11 on topic Headlights
I know this is an old thread, but a good price source for 6V #4020 sealed beams are here. normanlamps.com/specialty-lighting/seale...ealed-beam/4020.html
The following user(s) Liked this Post: MarkT, KennyV
Last edit: 20 Sep 2020 06:45 by dnaj11.
20 Sep 2020 06:44 #9
Replied by KennyV on topic Headlights
Do you by chance know the price?
71 Z50 Minitrail
20 CB500X Halfrica Twin
21 CRF300l Rally
20 Sep 2020 06:56 #10
