73 CT3 175 Carburetor question
- tsmitty1958
73 CT3 175 Carburetor question was created by tsmitty1958
Hi Guys,
Let me start by saying I bought an ALL original 1973 CT3 175. 2600 miles did not run. It's a beauty to look at. I figured if I couldn't get it to run I could either part it out or replace the motor.
The only thing missing is the tool kit.
Replaced all seals and found out why it didn't run and fixed that issue. The original carb was froze up. I bought one from fleabay that is a Mikuni which I was assured worked just needed cleaning. (I took advice from this forum). Cleaned it up only to find a huge fuel leak. In front of the banjo blot in the float chamber there seems to be a brass fitting of some kind. Just a hole. I looked at my other 2, 175's and there is a brass plug of some sort.
Does anyone know what should be there and can I find it somewhere on line?
I put a new carb on (from fleabay). She started right up. It runs great at idle but bogs when given throttle. Too lean?
I would like to put the old carb back in if it can be fixed because it fits the original air cleaner better.
Tsmitty
Tsmitty
21 Oct 2025 14:44
Replied by Gr8uncleal on topic 73 CT3 175 Carburetor question
That brass "plug" is actually the main jet, although I don't think that it's absence would cause a fuel leak. It could be that the tang on your float needs adjusting.
21 Oct 2025 23:46
- tsmitty1958
Replied by tsmitty1958 on topic 73 CT3 175 Carburetor question
22 Oct 2025 06:19
- tsmitty1958
22 Oct 2025 06:22
You probably did do it right. HOWEVER, Imgur have spat their dummy out and no longer operate in the UK, therefore I can't see your photo(s)!
- tsmitty1958
Dang. It's shows the open hole and fuel comes out of it.
22 Oct 2025 06:36
Replied by MarkT on topic 73 CT3 175 Carburetor question
This is about the third or fourth time this same question has come up on the CT3 carb.
Some have blocked it with a short screw but originally had a brass ball peened into the hole.
yamaha-enduros.com/index.php/forums/1972...tor-questions#104406
22 Oct 2025 07:39
- tsmitty1958
Thanks Mark.
22 Oct 2025 07:55
It kinda looks like some of the CT3 carb bowls had a manufacturing defect where the ball falls out.
Such an unusual problem that I've only seen come up on that model. And most Mikuni carbs have a few of those brass balls in various places to block a drill passage.
22 Oct 2025 08:28
- tsmitty1958
Thanks again Mark Very helpful. I ordered a 4mm brass ball. (100) $6. While I have you, the motor sounds like there is a little man in there banging on the case with a hammer when I accelerate. Going to remove the motor today and check the bearings. Will I need a crankcase splitter?
Tsmity
Tsmity
22 Oct 2025 10:00
