Reed valve petal replacements
  • Charlie72
  • Charlie72's Avatar Topic Author
Reed valve petal replacements was created by Charlie72
Does anybody know where to get reed valve petal replacements? Im scouring the internet and cant seem to find any..
These would be for a 1972 dt2 250.
23 Sep 2025 19:30 #1
Replied by Swoop56 on topic Reed valve petal replacements
Yamaha hasn't listed them as a separate part , but using logic , I guessed the part number would be 311-13613-00 .
Checking on Ebay , there was at least one vendor with some available .
311 is the DT2 specific part prefix number .
23 Sep 2025 20:51 #2
Replied by RTD2 on topic Reed valve petal replacements
Partzilla shows that they have them but they ain't cheap 10V-13610-01-00. I also looked at Boyesen which was one of the upgrade reed vendors. I don't see anything specific for a 72 but you may try calling them 800-441-1177
23 Sep 2025 21:21 #3
Replied by MarkT on topic Reed valve petal replacements
I just posted the same thing...  entire reed valve is still available new from Yamaha for about $125 which is what I'd do if the reeds actually need replacing.  The rubber coating is pretty old and hard by now.
Not a fan of Boyesen but I'm sure they do make them, they definitely used to but like Wiseco for a while, the catalogs don't show the older bikes anymore.
23 Sep 2025 21:28 #4
Replied by ZEFER on topic Reed valve petal replacements
yamabits in the UK has them
30 Oct 2025 10:28 #5
Replied by RT325 on topic Reed valve petal replacements
I've linked a couple of pages below from 1980 YZ80 because they're the same reed block except by memory they shaped the inside of the reed stops for better air flow--nothing realy--but i remember that from back in the day. So in the links the drop down under fitment has a thing saying see more & shows DT2-3 & RT2-3 for the gasket & the reed valve assembly Cost is getting up there but on Aliexpress where i go & i guess Amazon etc--if you knew what fits i'm sure there'd be a trick reed block for almost nothing with free shipping too. Just a question--what up with yours, or just want to replace the reeds because they're--nearly as old as me lol.
www.partzilla.com/product/yamaha/3TT-136...060beabae6fc1be05fe8
www.partzilla.com/product/yamaha/10V-136...060beabae6fc1be05fe8
Last edit: 01 Nov 2025 03:06 by RT325.
01 Nov 2025 03:02 #6
  • Charlie72
Replied by Charlie72 on topic Reed valve petal replacements
I was able to find some replacements that fit thee reed valve for a 1972 DT2 250.
These were the ones from Boyesen, below.
I replaced the original stainless steel petals, which looked to be in good condition, actually.
In the process I chewed up the small phillips screws holding the reed petals in place and replaced them with hex screws. The hex screws werent the same length so I had to cut them down with a dremel grinder and added some loctite for reinstallation.
Original reed petals: imgur.com/a/dFBAgbf
Boyesen Petals 1: imgur.com/a/OlCWfsb
Boyesent Petals 2: imgur.com/a/TVafl6I
Boyesen petals purchased: imgur.com/a/6s0ML0j
02 Dec 2025 22:43 #7
I'll try not to ruin your day but if i ran those again i'd use the original reed stops. Used them back when they were first invented & with just the bar supplied, but went soft over time & stuck so far open i had to push start. But flipped them over & completed the day ok. Cause was likely the "go fast" fuel we were using back then. Now nearly 50 years later i just thought original stops might give them an easier time. Used them in my sons YZ80--they used the same 250-360 RT2 DT2 reed block. Blimey it was about 47 years ago counting lol. Hope it all goes good for you.
02 Dec 2025 23:52 #8
