turn signals
- jsmith6752
turn signals was created by jsmith6752
My right front turn signal has 2 different voltages. It comes on at 6 volts but then drops to 3 volts instead of zero. This causes the light to not go out completely when blinking.It can't be the flasher because the left turn works fine. So, where is the 3 volts coming from? No easy answers for this one I am afraid. I have walked away several times. I am out of ideas. thanks DT360 Yamaha
22 Nov 2024 18:12
Replied by RT325 on topic turn signals
looking forward to the answer. always something new to diagnose. someone should write a book on unusual problems & their remedies. could be a best seller.
22 Nov 2024 20:02
- jsmith6752
Replied by jsmith6752 on topic turn signals
Hopefully I will have an answer.
23 Nov 2024 04:34
- pabdt
Replied by pabdt on topic turn signals
have you tried swapping bulbs from one side to the other? So both rear turn signals work ok?
can you post a bunch of high res pics for us to look at?
1969 Yamaha CT1 175
1969 Yamaha DT1S 250
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
23 Nov 2024 17:45
- jsmith6752
I have switched bulbs. The back turn signal has one bright and one not so bright. I will take some photo tomorrow. Thanks
23 Nov 2024 19:14
- pabdt
I think there is another possibility.
The handlebar switch for the turn signal selector may not be making a solid connection internally. The flasher needs load to apply heat to the flasher for it to work.
I wonder what would happen if you reversed the turn signal wires in the bucket. This would theoretically cause the L side to go DIM only and not off. If so, take the switch apart and look at it.
Another way to test this is to directly connect the BROWN/WHITE wire (ie from flasher) direct to the RIGHT TURN SIGNAL wire bypassing the handlebar switch. Of course, you would need the rear turn signal attached also to apply enough resistance to the circuit to heat the flasher.
1969 Yamaha CT1 175
1974 Yamaha DT125A
1969 Yamaha CT1 175
1974 Yamaha DT125A
- 2strokenewb
Replied by 2strokenewb on topic turn signals
have you tried applying ground to the ground side of the bulb/socket?
24 Nov 2024 05:57
- jsmith6752
great advise I will give it ago I took the handlebar switch apart and cleaned the contacts. I am trying to post some pics this morning.
24 Nov 2024 08:25
- jsmith6752
https://imguhttps://imgur.com/73M imgur.com/73MHNhs.com /73MHNhs not having much luck
- jsmith6752
https://imguhttps://imgur.com/73Mhttps://imgur.com /73MHNhsHNhsr.com/73MHNhs not having much luck
24 Nov 2024 08:52
