Cylinder stud installation - dry, lubrication or loctite?
- Bdee
Cylinder stud installation - dry, lubrication or loctite? was created by Bdee
I didn't find anything in the service manuals and searching the web did not provide definitive guidance.
What do people do here? Mine is a CT3 if it matters.
grazie mille
grazie mille
22 May 2024 14:53
Replied by RT325 on topic Cylinder stud installation - dry, lubrication or loctite?
Personally I just lube things like that & screw right home. Just curious as to why you removed those long-ish studs out of the case on the ct3.
22 May 2024 15:06
- Bdee
Replied by Bdee on topic Cylinder stud installation - dry, lubrication or loctite?
Thanks!.
I was lead to believe that it would be good maintenance to replace them with new ones. "How 2 Wrench" youtube videos, specifically.
22 May 2024 15:14
I had a nightmare time with my 360 as ended up with cases that had no studs fitted.
Not sure how that came about but were cases i got with a lot of old parts.
So in the process of removing my old ones to transfer over i think it was two that broke off flush in the case.
Not even sure they were Loctite'd in but probably were, & couldn't get enough heat into around it with what i had to heat with.
Mine were 10mm & yours are 8mm by memory.
22 May 2024 15:35
- Bdee
Mine came out easily. The modern replacements are the same dimensions but they are flat at both ends and the threaded sections have different lengths.
22 May 2024 15:43
Ok, yep i'd expect top end to be rounded as original.
Are they genuine originals.
Bottom end normally are flat & the thread rolled fractionally tighter so it's a really snug fit in the alloy.
Hope she's all good.
22 May 2024 15:52
