Fuel Petcock question
- adguy2112
Fuel Petcock question was created by adguy2112
hi all, new member to this forum and asking my first question. I'm in the process of restoring a '72 LT2 my son grew up riding for my daughter and having the, often seen, leaky petcock issue. I've tried some of the petcock rebuild kits seen on ebay with fairly miserable success. In looking at new petcocks there seem to be some vast differences in the price with some at about $10 up to $60 (Partshark). I recently bought a new clutch cable on Partshark and it's looked to be a genuine Yamaha part...perfect. That said, I'm wondering if anyone can point me to a reliable site for a solid petcock that isn't so expensive. Usually you get what you pay for but this little gem is nickel and diming me to death. Appreciate any replies.
16 Jul 2021 13:03
- Mothersbaugh
Replied by Mothersbaugh on topic Fuel Petcock question
I am unaware of any genuine Yamaha petcock rebuild kits. Was there a manufacturer given for the one you bought? When I rebuild a petcock, I buy genuine Yamaha parts, and I buy the screws and mounting fiber gaskets as well. I also clean all the metal parts with a soak in Berryman's carb cleaner. It's more expensive, but I've never had a Yamaha petcock rebuilt with Yamaha parts fail to seal completely.
The following user(s) Liked this Post: Rick C., MarkT, RT360Fan, Steve F
16 Jul 2021 16:57
Replied by RT325 on topic Fuel Petcock question
Pretty sure its this style & can't go wrong with the price. Have bought a few similar off 'aliexpress' that work ok.
www.aliexpress.com/item/1005002130072393...924e-489ce64dceb3-26
16 Jul 2021 17:19
Replied by MarkT on topic Fuel Petcock question
Ebay has dozens and dozens for in the $8 range with free shipping. I can't recommend a specific one but I've used them without issues.
Hint: 78-81 DT175 uses the same "thread on" petcock
The following user(s) Liked this Post: Rick C., yamahahaha, adguy2112
16 Jul 2021 17:32
- adguy2112
Replied by adguy2112 on topic Fuel Petcock question
In fairness to Yamaha the recent kit I tried was for a Honda (can I say that word here) and it wasn't genuine parts. The aluminum in the Yamaha LT2 petcock, I have, has experienced some level of electrolysis in the bowl and body above the bowl with severe pitting. I did have it in a B-9 dip for a several hours. The mating surface for the lever, where it really counts is borderline and may still be ok with a rebuild. I was just thinking it would be safer to buy a complete unit. I was mainly looking to know if my best bet is to pony up the big bucks or if anyone had a good experience with any other options. I appreciate your recommendation that using genuine parts and rebuilding the one I have may be the best, least expensive option.
16 Jul 2021 17:42
- adguy2112
That's a good option for the '79 DT100 which I have also. I think I tried the petcock from that tank onto the '72 tank and recall the threads were slightly different. I do like the ability to add tension from the rear locknut on this version. I may disregard my desire to keep it original in this case if the swap carries over. I'll check it again. Thank you.
16 Jul 2021 17:49
I hadn't noticed the tension bit, how trick is 'that'.
16 Jul 2021 20:19
Threads are not different. Yamaha petcock part number is the same for the LT2 and the 78-81 DT175 I have both model bikes.
16 Jul 2021 20:58
I also noticed you said 79 DT100. I doubt it would be different but it could be. The 78-81 DT175 isn't. Reason I mentioned the later DT175 is because an ebay search will turn up a lot more choices than LT2 will
16 Jul 2021 21:03
