I need a new coil for a 1969 DT1-B 250.
- pmb
I need a new coil for a 1969 DT1-B 250. was created by pmb
I have been at war with my DT1-B 250. I am struggling to get it to run properly. I have discovered that my coil is no good and I need a replacement. I have been searching for a NOS replacement but can't seem to find one. I am wondering if anyone out there knows of a good aftermarket alternative?
Thanks for any suggestions.
Pmb.
Pmb.
06 Jul 2021 18:39
Replied by MarkT on topic I need a new coil for a 1969 DT1-B 250.
Have you checked with DEET for a coil? He might have one.
06 Jul 2021 18:51
- pmb
Replied by pmb on topic I need a new coil for a 1969 DT1-B 250.
I don't know Deet. I am still somewhat new to this forum. I have looked on eBay for NOS. I have seen lots of lots of "fits your vehicle" aftermarket stuff on Amazon and the like. I figured I would see if anyone here has had success with something other than an OEM coil.
Thanks. Pmb
Thanks. Pmb
06 Jul 2021 19:35
Replied by RT325 on topic I need a new coil for a 1969 DT1-B 250.
Before you spend money & possibly don't end up with a cure--Love these type of problems to get my--or our--teeth into. So can we help please. Heaps of single wire magneto type of coils on the internet.
06 Jul 2021 19:54
www.2fastmoto.com/Yamaha-6V-12V-Ignition...-250-400_p_1679.html
Not sure why they say 6 or 12 volt but its a single wire AC 'not dc' ignition coil & should do the trick. But--back to what's going on with the bike please?.
- DEET
- Moderator
Replied by DEET on topic I need a new coil for a 1969 DT1-B 250.
What makes you think it is bad?
06 Jul 2021 20:30
- pmb
Well first I want to say that I dug a little deeper into this website. I should have looked through the other sections in an effort to read what has already been asked and discussed in the forum before I made my post. I read, in a different thread, a reply from MARKT where he mentioned that Deet was able to cut the coil open and solder a new spark plug wire onto the coil.
I just got through cutting my original coil open just enough to get the old wire out and expose the contact. I am going to try the repair method first and solder a new length of wire on and see what happens.
I appreciate the the link to the aftermarket coil. I will check it out...
As far as the running issues with my bike goes... that's a long tale of chasing my tail through a variety of problems that all manifested in a bike that would not rev cleanly. Had no power. Always felt like it had a fouled plug. Backfired and would seem to run fine until I would try and ride it.
I have a sudco carb on it. That was supposed to fix everything. Nope! I then replaced the crank seal behind the mag and that helped a bunch. The old seal was hard and non compliant.
At this point I am hopeful that I am able to get it tuned up with carb adjustments.
I determined that I had a compromised wire on my coil and I want to eliminate it as another variable to my puzzle.
Thanks for for your reply.
Pmb
Pmb
06 Jul 2021 20:53
- pmb
Hi DEET!
I just saw your question about what made me think my coil was bad.
answer: the spark plug cap was not original and there was a different one that was poorly spliced on. I attempted to solder on a new piece of wire. I also bought a new 5k ohm NGK ceramic cap.
At first it seemed like it was good but then I noticed the bike missing/hesitating. I checked to see if the new cap was secured properly and when I tried to check that it was screwed on tight, the spliced section of wire pulled off leaving only a single strand of wire still connected to my solder joint. So I would call that a fail. I ended up making the wire a bit too short and when I tried to plug onto the side plug on my head I believe I stressed the cable right where the solder joint was and snapped all but one of the strands.
I now have the original coil cut open just around where the cable enters and is pushed onto a spike at the back end. I just need to find some cooper core wire and I think I can get the original coil back in operation.
Any my advice is always welcome.
Thanks to all of you guys!!!
pmb
pmb
06 Jul 2021 21:21
- pmb
I thought I would post a couple pics of my coil.
06 Jul 2021 21:32
