dt175mx inlet and exhaust sizes
- ajhuxley
Replied by ajhuxley on topic dt175mx inlet and exhaust sizes
thanks, I believe the compression is good, the bike goes too well! But its easy to do so I'll give it a quick check. This idle is good once it settles, it just seems to be a weak mixture after reving or running. Stays at 2100rpm for about a minute and then it literally just drops back to normal idle.
1980 DT175mx - 99% original
1981 RD350LC - restored
1980 CB750fa - restored
1982 GS550Ez - winter hack
23 Mar 2020 01:05
#11
- ajhuxley
So finally got the leak down test going and discovered a leak on the inlet to reed block joint. Everything else looks good but can't say for sure until I seal this up so it holds pressure
As its rubber to alloy, whats the recommended sealant to use on this joint?
The wine makers stopper with a shrader valve for the inlet and a second stopper for the exhaust worked well for a cheap leak down tester. I took the attached pictures while its still on the bike, I'll do some better ones when I take it all off if its useful to others
The following user(s) Liked this Post: 2fishkev, FrankC
01 Apr 2020 08:51
#12
Replied by MarkT on topic dt175mx inlet and exhaust sizes
Nice job!
I use the non-hardening Yamabond (same as used to seal the center cases) or Permatex Motoseal grey.
The following user(s) Liked this Post: 2fishkev, FrankC, ajhuxley
01 Apr 2020 09:29
#13
- ajhuxley
Hi Mark, out of interest, where do you position the piston for doing leak down tests?
Cheers
Adrian
Cheers
Adrian
02 Apr 2020 09:31
#14
Some people like to have the piston at or near BDC as with the transfer ports open the pressure/vacuum gets to the top of the piston easier...
I don't care where the piston is. At worst, it only takes a few seconds for the pressure/vacuum to bleed past the piston and piston ring end gaps even if piston is at TDC. I use a hand pump (Mityvac) to apply the pressure or vacuum which is kind of slow and the pressure equalizes so fast I don't even notice it.
The following user(s) Liked this Post: ajhuxley
02 Apr 2020 09:42
#15
