1978 DT 400 timing
- 78Dt400Kart
1978 DT 400 timing was created by 78Dt400Kart
How do I check/ set the timing after the flywheel key sheers? I haven't been able to figure out how to do that; the manual just says line up the marks UNLESS THE FLYWHEEL KEY SHEARED.
Replied by RT325 on topic 1978 DT 400 timing
Nothing to worry about regarding timing. Just replace the key & 'do it up Tight' this time & she'll be all good.
Just reading again what you say the manual says--all they''ll mean [confusingly] 'is' that if the key is sheared off then lining up the marks on the flywheel & stator will have no relation to where the piston is due to key gone. Don't worry--unless you've moved the stator plate on the three screws away from original marks the screws have made & if so then just fit the plate where you can see the screws have been--easy as.
I keep using this pic of mine to demonstrate how tight they need to be. Ok i get a bit brutal but it's a big thread & it's super important to be tight--as i'm sure you now realise although i don't know of course who fitted your one.
The following user(s) Liked this Post: FrankC, 78Dt400Kart
Replied by MarkT on topic 1978 DT 400 timing
Not sure what manual you have... can't recall seeing one that mentioned "unless you have a sheared key".
1978 is CDI and as long as you haven't disturbed the stator plate, just replace the key and timing will be back to stock.
If you have removed or rotated the stator plate, there should be factory alignment marks on the stator plate and engine case... often really hard to see on that model... usually about at the 12 to 1 o'clock position.
If marks are not there, you need a dial indicator and can make a new one... not too hard... but marks should be there
21 Nov 2019 13:44
- 78Dt400Kart
Replied by 78Dt400Kart on topic 1978 DT 400 timing
thanks a ton! I now understand the manual was saying that the flywheel and the case marks should line up unless the key sheared. I interpreted as they should be made to line up unless key sheared. I've got to hand it to these engines; They seem to be simple enough to not fail too often. I had my premix pump fail but not a problem i just adjusted my jetting for premix. But just seeing a 41 year old engine purr with only minor restoration gives me an odd sense of joy. I got mine& all the bits to make it run for $150 pretty stout engine for that price. Hope you guys don't mind its now powering a gokart but hey better someone use it than lose it right?
21 Nov 2019 16:03
Video of the Kart running would be great sometime. sounds like a 'weapon'.
21 Nov 2019 18:21
- FrankC
- Solution Contributor
Replied by FrankC on topic 1978 DT 400 timing
Good thread. I save this to my favorites.
The following user(s) Liked this Post: 78Dt400Kart
21 Nov 2019 18:52
- bluntz465
Replied by bluntz465 on topic 1978 DT 400 timing
You may want to lap the wheel to the shaft with some polish a bit when you replace the woodruff key maybe keep it from recurring.
1982 Yamaha IT465J
1982 Yamaha IT465J
22 Nov 2019 17:50
- Bobv07662
Replied by Bobv07662 on topic 1978 DT 400 timing
When I checked the timing on my 78 DT400E it was about 1/16 of an inch past when the piston was in the right place. That indicates that it was "advanced". By the way the stator plate and engine case marks are aligned and have never been altered. (3000 mile bike) I remember having a similar timing discussion here once before with a member looking for info on a bike's overheating and detonation concerns.
The following user(s) Liked this Post: FrankC, 78Dt400Kart, DT400FRANK
22 Nov 2019 18:00
Not certain with the 400 but generally the cdi timing alters a little from the set mark even on 400's. Often find a long mark with a short mark either side & depending on revs it'll move within that range, so it's only realy on 'that' mark within a certain rev range. I know my suzuki mudbug 100cc bucket racer tweeked to rev to 14 grand [in theory with porting & pipe to match] altered heaps when i strobed it. The advance was way up there at low revs which it needed to try & get the best out of wild porting which robs the low end of any power it had, [if it had any in first place] but retarded of to about 16 degrees at high revs or even almost tdc at 14000 in that extreme motor [hand grenade but fast while it lasted]. Used to often throw RG400 pistons out the exhaust so started again with milder porting. I remember one 30 lap GP at the airforce base & [while leading luckily halfway through] the liner broke off below the inlet & locked it solid while passing between two other bikes when catching tail enders. Not sure who got the biggest fright but stayed on & skidded to a stop. One other mudbug motor [my boy this time] in another yearly GP at base & was going well then next thing the end broke off the crank & disappeared never to be found haha. We used to run without the mag cover to let as much heat out as possible but we still ran the full flywheel mag as couldn't afford an RM small rotor unit & the crank broke flush with the seal & took off into the fuel storage area as we used the streets within base back then plus a tarmac section. Fun days those & miss them heaps. Airforce guys had all the tricks & all the gear to do it with. The times have changed unfortunately & can't race out there anymore. Sorry--off subject--again.
22 Nov 2019 19:12
- 78Dt400Kart
I just put it up for the winter so i can't get any videos up for a while. But I did have a photo of the front end handy.
