Bushing
- wayno
Bushing was created by wayno
Is the torsion arm bush available anywhere for a dt400c? Also the rubber cover on chain side of the swing arm?
Cheers Wayne.
Cheers Wayne.
- DEET
- Moderator
Replied by DEET on topic Bushing
Any particular bike? Yamaha? Honda?
12 Nov 2019 08:07
- wayno
Replied by wayno on topic Bushing
Oops..edited.
12 Nov 2019 08:13
- MACE6772
Replied by MACE6772 on topic Bushing
PART # 363-22123-00-00 available on US Ebay. $ 15.99 + 6.99 shipping. It's in Texas. For rubber part, check for same part for 250 Suzuki. It's called a " chain defense". I have one on my 75 DT 250. Works perfect and it's less than $ 10.00 . OEM Yamaha part is currently on E bay for $ 60.00. Update: just went to E bay. The Suzuki boys must have caught on , their part is now selling for $ 45-80.
Replied by RT325 on topic Bushing
In theory & in my experience, i've never seen one of those bonded rubber bushes wear out. No matter if its in a old yamy 50 swing/arm or a DT1 brake plate anchor or the frame end of the anchor arm the problem is only 'ever' the bolt is loose & nothing more. I suppose in hindsight that if the bolt had been loose for 40 years then it could wear the steel internal part of the bush or wear the bolt, from letting that do the work of the bush stretchy bonded rubber. But even in that extreme case, just tightening the bolt would fix it if not dangerously worn like i've seen some V50 scooter swing/arm bolts.
Replied by Gr8uncleal on topic Bushing
It could just be missing.
01 Dec 2019 01:32
- wayno
Gr8 it is there and appears ok, just that as it's off for painting I thought it might be a cheap item to replace.
07 Dec 2019 09:19
Reminds me of the time, 30 odd years ago, when I sent off a RD250 or RD400 frame for shot blasting and powder coating. It must have had plastic or nylon bushes in the swing arm and I'd forgotten to remove them - nice and melted they were!!
07 Dec 2019 10:21
